Strange Problem With First Layer?? May 05, 2014 08:34PM |
Re: Strange Problem With First Layer?? May 05, 2014 09:18PM |
Re: Strange Problem With First Layer?? May 05, 2014 09:28PM |
Re: Strange Problem With First Layer?? May 05, 2014 09:39PM |
Re: Strange Problem With First Layer?? May 05, 2014 11:07PM |
Re: Strange Problem With First Layer?? May 06, 2014 03:42AM |
it is what goes in the extruder in fact that's how you calibrate the extruder which is a very important piece of the calibration process there are many posts on itQuote
jbernardis
You say that when you tell it to extrude 100mm that it extrudes 100mm. I assume you don't mean this literally. Extrusion is what comes OUT of the hot end. What you want is to measure 100mm on the way INTO the extruder.
Re: Strange Problem With First Layer?? May 06, 2014 06:30AM |
Re: Strange Problem With First Layer?? May 06, 2014 08:07AM |
Re: Strange Problem With First Layer?? May 06, 2014 09:13AM |
Re: Strange Problem With First Layer?? May 06, 2014 09:34AM |
waitaki
I wouldn't muck about with Z offsets - just set your nozzle gap properly and not 0.2mm but 0.1mm. Do this with the heat bed up to temp and the nozzle at or near print temp. A piece of copy paper should lightly drag under the nozzle as was rightly suggested by John D.
Re: Strange Problem With First Layer?? May 06, 2014 04:32PM |
Re: Strange Problem With First Layer?? May 06, 2014 05:05PM |
Re: Strange Problem With First Layer?? May 06, 2014 06:37PM |
Re: Strange Problem With First Layer?? May 06, 2014 06:45PM |
Re: Strange Problem With First Layer?? May 07, 2014 06:29AM |
manton
If 0.2mm is too high, why does it work so well? I always print at 0.2mm, and it is very rare that I have adhesion issues. I've had far more problems printing at less than 0.2mm. That being said, I am not printing on glass directly. If printing with PLA, dilute white glue works well, ABS works well on kapton tape, both on a heated bed. Lately however, I've had good success with both material types printed on Ultem PEI.
Re: Strange Problem With First Layer?? May 07, 2014 05:27PM |
Re: Strange Problem With First Layer?? June 05, 2014 10:02AM |
Re: Strange Problem With First Layer?? June 05, 2014 03:52PM |
Re: Strange Problem With First Layer?? June 05, 2014 09:42PM |
Re: Strange Problem With First Layer?? June 05, 2014 11:55PM |
Re: Strange Problem With First Layer?? June 06, 2014 09:19AM |
Re: Strange Problem With First Layer?? October 20, 2014 06:48PM |
Re: Strange Problem With First Layer?? October 20, 2014 06:55PM |
Re: Strange Problem With First Layer?? October 20, 2014 06:59PM |
Garry Bartsch
I have ordered the Ultem and am going to try it adhered with high temp silicone. I'm wondering if it would be best to use a laminate roller to press the Ultem to the glass to make it as flat as possible and eliminate bulges of silicone? Would such a method leave enough silicone between the two materials for good bonding? It might not be good to starve the joint.
Re: Strange Problem With First Layer?? October 20, 2014 07:26PM |
Re: Strange Problem With First Layer?? October 20, 2014 07:33PM |
Re: Strange Problem With First Layer?? October 20, 2014 08:41PM |
Re: Strange Problem With First Layer?? October 20, 2014 09:17PM |
Re: Strange Problem With First Layer?? October 20, 2014 09:34PM |
Re: Strange Problem With First Layer?? October 20, 2014 11:44PM |
