Hi there reprapers
I have just built a corexy printer with auto bed leveling servo probe.
There are number of issues come up every now and then.
1. When machine is turned on, the servo will shuffle a little for a short moment
The cable is around 40cm long
2. The X axis is moving in the wrong direction, I've tried to invert the X axis direction from the firmware,
but both X and Y directions will be inverted I.e. X becomes Y, and Y become X
3. The servo stops working every now and then, often needs to reset printer and keep all stepper motor cables well away from the servo cable to get going again.
But this problem will come up again after a while, not sure why.
4. I'm using an LCD "RepRapDiscount Smart Controller" to print offline, the Z movement is far too slow at the moment when I turn the knob
Where in the firmware do I need to alter to change the speed of the Z movement while "Not printing"
5. Due to the printer design, the SD card slot need to be located at the front panel of the printer,
I'd like to know how do other reprapers extend their SD Slot to other place of the printer ?
Many thanks
