Optical end stop help Ramps 1.4 Marlin firmware May 09, 2014 02:12PM |
Re: Optical end stop help Ramps 1.4 Marlin firmware May 09, 2014 07:23PM |
Admin Registered: 15 years ago Posts: 7,341 |
Re: Optical end stop help Ramps 1.4 Marlin firmware May 09, 2014 07:44PM |
Re: Optical end stop help Ramps 1.4 Marlin firmware May 09, 2014 10:29PM |
Re: Optical end stop help Ramps 1.4 Marlin firmware May 10, 2014 01:33AM |
I should take the "S"ignal wire to ground? Then should I put the ground to the signal pin? Then again with S to +5v? where do I put the +5V line when I do this? I am not convinced this will work as the stop needs constant power to operate |
Re: Optical end stop help Ramps 1.4 Marlin firmware May 10, 2014 01:55AM |
Re: Optical end stop help Ramps 1.4 Marlin firmware May 10, 2014 11:49AM |
