A new Reprap printer and my blog about it May 11, 2014 08:00PM |
Re: A new Reprap printer and my blog about it May 11, 2014 08:48PM |
Re: A new Reprap printer and my blog about it May 12, 2014 12:59PM |
Re: A new Reprap printer and my blog about it May 13, 2014 07:26AM |
Re: A new Reprap printer and my blog about it May 14, 2014 01:14PM |
Re: A new Reprap printer and my blog about it May 17, 2014 07:10PM |
Re: A new Reprap printer and my blog about it May 21, 2014 07:18PM |
Re: A new Reprap printer and my blog about it May 24, 2014 05:03AM |
Re: A new Reprap printer and my blog about it May 31, 2014 01:47PM |
Re: A new Reprap printer and my blog about it May 31, 2014 07:58PM |
Re: A new Reprap printer and my blog about it June 08, 2014 12:06AM |
Re: A new Reprap printer and my blog about it June 08, 2014 03:34PM |
Re: A new Reprap printer and my blog about it June 09, 2014 05:57PM |
Re: A new Reprap printer and my blog about it June 17, 2014 02:52PM |
Re: A new Reprap printer and my blog about it June 18, 2014 03:54PM |
Ralph.Hilton
Can you provide a link to the website of the vendor please.
The design looks to me to be inadequately braced to avoid X and Y wobble at the top of tall prints with fast movement of the extruder.
Definitions of screws and bolts vary a lot. Vrheinen seems to be patronizing a little in asserting the rightness of his definitions. The basic definition I was given in school in England 50 years ago is that a bolt has a nut and a screw does not. Google need to add translation between English and American in their choices.
Re: A new Reprap printer and my blog about it June 20, 2014 04:07PM |
Re: A new Reprap printer and my blog about it June 20, 2014 09:11PM |
Re: A new Reprap printer and my blog about it July 01, 2014 07:12PM |
Ralph.Hilton
Personally I mounted my filament spool on a wall behind my machine. That way I have more warning if badly wound filament snags.
Also, having a weighty spool mounted at the top of a machine seems to me to increase the probability of mechanical resonance and thus oscillations.
I can't really see from the pictures if there is room - can you fit a piece of aluminium,mdf, dibond or acrylic sheet to the back and/or front of the upper part of the Z profiles? It would extend across the length of the X axis and have a height of 15cm or so. That would brace the top of the machine in the X direction. The principle is shown in the Mendel90 and Prusa links below.
Then it needs bracing in the Y direction. This could be a sheet or rods or extrusion. I would suggest looking at the Mendel90 design and the way the 2 sheets of dibond brace the top of the machine Y axis in a simple inexpensive fashion. [reprap.org]
You could also look at the way this prusa version is stabilized in the Y direction: [reprap.org]
An alternative using a triangularly placed extrusion is shown in this design: [www.thingiverse.com]
garyhlucas
A couple of thoughts here.
Nice job on your blog!
Look for triangles. Do you see any triangles? No? Then your printer frame will not be stiff as the triangle is the only stiff shape in nature. Rectangular frames are notoriously flexible. You need triangles. If you have room for X bracing, which uses only tension you can use just strips of flat metal across corners. If you can only brace in one direction then it must be a stiff member also and you will need to use extrusion for that.
I see you using a tape measure, and I take note of where you measure from. A tape measure is not a good tool for locating rails and squaring a frame for a machine that moves on linear rails. Also you need to make measurements that do not add up your errors. Parallel rails need to be REALLY parallel. So always measure rail to rail not rail to other frames, except for one rail which is the reference to the frame. You need to use a gauge to set frames and rails. Make them from threaded rod, a couple of nuts, a coupling nut and a couple of smooth headed carriage bolts. Adjust the length of your gauge as close as you can to the measured distance. Then use it between the rails and the frames with a feeler gauge to get the rail spacing down to 0.001" or 0.025mm at worse near the mounting points. Do the same with the frame and get it as true as you possible can. Get those 4 Z rails perfect to each other using 3 allthread gauges, left to right, front to back, and diagonally.
Your Z axis is problematic. You have 4 short bushings widely spaced with the screws in the middle and that is very unstable. The short bushings can't keep it from tilting, then can only bind. 3 bushings, two spaced apart on one rail and one as a guide on the other rail would be much better.
Some years ago I was building reciprocating bagging machines. After they were built it usually took two weeks of tuning before they would make good bags. We then built one that I checked every measurement as the mechanics installed parts, and made them fix any that did not match the drawings. When we finally started it, it was in perfect tune 15 minutes later! The mechanics asked how that happened. I told them we simply made it correctly right from the start.
Re: A new Reprap printer and my blog about it July 07, 2014 08:26AM |
Re: A new Reprap printer and my blog about it July 31, 2014 08:47AM |
