Printing vertically
Posted by Govanator
Printing vertically
May 14, 2014 09:53PM
Hi folks,
I got a simple stupid question, but i cant find the answer.
How do i change the way objects are printed (horizontally or vertically)
It must be a setting in slic3er but i cant find it.
Thanks
Edited 1 time(s). Last edit at 05/14/2014 09:54PM by Govanator.
Re: Printing vertically
May 15, 2014 03:19AM
You need to do it before Slic3r gets hold of it. Netfabb for instance will allow you to rotate models anyway you wish.
_______________________________________
Waitaki 3D Printer
May 15, 2014 09:28AM
Pff this is so annoying to find how and it must be so simple ! :s
I got the program i can rotate it, but i cant find the real way to make it print vertically
May 15, 2014 03:44PM
Slicer lets you rotate STLs around the Z axis with its Plater/45ccw|45cw|rotate buttons.
Netfabb lets you rotate around X,Y or Z with its rotate tool.
To use these tools to rotate a part from horizontal to vertical, you could open it in Netfab, rotate 90 degrees around X or Y, export it as STL, then open the new file in slicer.
