*Nearly* solved (so close)- Whats wrong with this print ?
Posted by eci22
May 17, 2014 08:33AM
Updated Further down the thread
Hi all,
Im trying to print a prusa i3 Y corner and i'm having some issues as seen in the pictures. The main thing is how out of line the part is as it moves up. If anyone can give me some pointers it would be much appreciated.Thanks
It is printed on its default orientation from the prusa repository.
Infill:0.2
Speed: 60
First Layer height 0.2
All other layer height 0.3
Nozzle: 0.5
Filament 3mm
Edited 2 time(s). Last edit at 05/18/2014 01:29PM by eci22.
open | download - IMG_20140517_130007.jpg (99.2 KB)
open | download - IMG_20140517_130117.jpg (68.2 KB)
open | download - side.jpg (346.8 KB)
Re: Whats wrong with this print ?
May 17, 2014 09:50AM
looks like there may be multiple issues.
under current on the motor - missing steps
print temp too low
belts not tight enough
loose hot end
printing too fast
those are the things ro start with...
May 17, 2014 11:14AM
I'm not as experienced, but my first instinct was it being too hot.
Edited 1 time(s). Last edit at 05/17/2014 11:14AM by MrDoctorDIV.
Realizer- One who realizes dreams by making them a reality either by possibility or by completion. Also creating or renewing hopes of dreams.
"keep in mind, even the best printer can not print with the best filament if the user is the problem." -Ohmarinus
May 18, 2014 10:43AM
z wobble you have that looks to me your 1st issue then too fast try slow things down if its 60 try 30 what machine you got?
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
*Update* nearly there!
May 18, 2014 01:14PM
Hi all,
thanks for taking the time to respond, much appreciated.
I made a mistake in my first post, it wasn't 60 mm/sec for speed it was 30. I slowed down a bunch of parameters and the results are much much better!
2 issues remain:
1. Theres a small gap where the M8 rod goes (see 'gap' pic)
2. There are burn marks on the PLA.(see 'burn' pics)
For #2 i suspect that slowing down from 30mm/sec to 20 is causing the filament to stay in the nozzle to long and burning on slow extrudes. Llowering the nozzle temp should solve this, these were printed at 180 degrees Celsius, maybe 175 is in order?
Any ideas for these 2 issues ? #1 is a headscratcher for me because the rest of the part prints really well.
The machine is a prusa i3
Edited 1 time(s). Last edit at 05/18/2014 01:28PM by eci22.
open | download - Gap.jpg (87.5 KB)
open | download - Burn 1.jpg (102.5 KB)
open | download - Burn 2.jpg (81.2 KB)
Re: *Nearly* solved (so close)- Whats wrong with this print ?
May 18, 2014 02:39PM
Hm. I can say that some hotends are really bad at telling temp. On my Solidoodle, pre E3D upgrade, I printed PLA at 162C and got near perfect prints [I'm now having to rediscover how to print with my E3D, entirely different world and settings]. Turn your printer on and heat up the hotend to 150C and try and push your filament by hand, increase by 5C each until it reaches the point that turning it up doesn't change how well it flows, that's your temp.
