Hi folks,
In Configuration.h, I set the variables as follows:
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true
but it appears that the y axis is inverted. I wanted to do a sanity check:
The y axis increases going away from the motor, correct? So for example, in this picture:
reprap.org]
The y axis increases going out of the picture towards the viewer, and decreases going into the picture away from the viewer, is that correct? Thanks!
Edited 1 time(s). Last edit at 05/23/2014 04:33PM by foul_owl.
