need help while printing print get off course
Posted by papo
May 23, 2014 11:09PM
when i print i can see print getting of course holes don't align
dose happen quite often end up stopping print x y z run very smooth
need help thank you i put pics printer megatronics v2.0amp
power supply 12v 2amps
open | download - photo 2.JPG (49.6 KB)
open | download - photo 4.JPG (44.8 KB)
open | download - photo 1.JPG (36.9 KB)
open | download - photo 3.JPG (40.6 KB)
open | download - photo.JPG (132.8 KB)
Re: need help while printing print get off course
May 24, 2014 06:38AM
Skipped steps. Check for mechanical problems, make sure the carriage moves freely along the axis, and try a little more current to the motor.
May 24, 2014 10:08AM
2 Amp power supply? Is that a typo? If not you are way under powered, which would cause your issue.
May 27, 2014 07:29AM
i put in a 14amp power supply still no luck i slowed down infill speed and some other settings
better but still goes off course its killing me help
May 27, 2014 09:02AM
reduce the extrusion multiplier in your slicer
May 27, 2014 01:18PM
Have you tuned your steppers? Second thing I check after friction.
Realizer- One who realizes dreams by making them a reality either by possibility or by completion. Also creating or renewing hopes of dreams.
"keep in mind, even the best printer can not print with the best filament if the user is the problem." -Ohmarinus
May 27, 2014 05:35PM
Hi Papa,
Pulleys could be loose, mark them to see if they are slipping. I've seen this happen and the result is similar to your prints... sort of random shifting usually in one direction.
Looks like that is fishing line instead of a belt right, so the belts are probably not too tight.
Otherwise, like others mentioned, stepper motors count need the current adjusted... either too much or too little. Turn the current down until it doesn't move, then slowly bring it back up until they are strong.
Here's video of me tuning one of mine:
[www.youtube.com]
Let us know how it goes.
