Prusa i3 heated bed/Kapton question June 03, 2014 09:47AM |
Re: Prusa i3 heated bed/Kapton question June 03, 2014 06:41PM |
Re: Prusa i3 heated bed/Kapton question June 03, 2014 06:50PM |
Re: Prusa i3 heated bed/Kapton question June 03, 2014 09:33PM |
Re: Prusa i3 heated bed/Kapton question June 04, 2014 06:13AM |
Re: Prusa i3 heated bed/Kapton question June 04, 2014 08:26AM |
Re: Prusa i3 heated bed/Kapton question June 04, 2014 01:19PM |
SimianSteam
Ah, OK. So coating the bed with Kapton is one of several possible options, but it's used in other parts of the build. I'll go ahead and order some and then play around with bed treatments once I finish the build. I'll be starting out with PLA and Blue Painter's Tape anyways.
I am a little confused about the "easy cleaning" reasoning. What could be easier to clean than a sheet of glass???
Re: Prusa i3 heated bed/Kapton question June 04, 2014 01:41PM |
Re: Prusa i3 heated bed/Kapton question June 04, 2014 02:59PM |
Re: Prusa i3 heated bed/Kapton question June 06, 2014 10:20AM |
Re: Prusa i3 heated bed/Kapton question June 06, 2014 01:56PM |
Re: Prusa i3 heated bed/Kapton question June 06, 2014 02:34PM |
Re: Prusa i3 heated bed/Kapton question June 07, 2014 02:27AM |
Re: Prusa i3 heated bed/Kapton question June 07, 2014 08:18AM |
Ok, so adhension is better/improved with Kapton for you ?Quote
drmaestro
I have tried Kapton and had some good results. Howrver the hotend was too low and removed the tape when it hit the edge. My problem is the width of the tape I have, which is 4 cm. I need to lay down 5 pieces to cover the entire bed, which increases the risk of being removed by the hotend. I have ordered a 20 cm wide tape roll, so we'll see if it is a better solution.
Re: Prusa i3 heated bed/Kapton question June 09, 2014 11:18AM |
Re: Prusa i3 heated bed/Kapton question June 09, 2014 03:34PM |
Re: Prusa i3 heated bed/Kapton question June 09, 2014 04:19PM |
