Which Motor Wires should i use?
June 05, 2014 11:25AM
Hi!
I just got these motors:
[imgur.com]
i got ramps 1.4 which have 4 outputs per motor.
How can i check which of those wires i have to use and what order should i connect them?
Edited 1 time(s). Last edit at 06/05/2014 11:26AM by Gogolian.
A2
Re: Which Motor Wires should i use?
June 05, 2014 12:01PM
[www.automationtechnologiesinc.com]
Did the motors come with the dampeners, and if so got a link.
June 05, 2014 12:19PM
I'm not quite sure what you mean by the dampener (english is not my main language) smiling smiley Do you mean those metal parts on top?
And i found this:
[reprap.org]
I think i'll give it a try
June 05, 2014 09:10PM
Gogolian
And i found this:
[reprap.org]
Use a led, is the easiest way, check this:
[youtu.be]
also, manufacturers often wive the information about wiring, you'll get 2 pairs A and B, you can connect them in any order:
(1) A- A+ B- B+
(2) A+,A- ;B+; B-
(3) B+ B- A+ A-
(4) B- B+ A- A+
Always Power off the board before make any swap!
Why? because you can flip over the cable and plug it upside down and (ie.) setup 1 becomes 3 and motor just spins backwards, ( 2 becomes 4 in the same way)
You'll notice strage movements and vivrations if you wire it in the wrong way, just as seen in next video tutorial of the same guy on youtube: [youtu.be]
Edited 1 time(s). Last edit at 06/05/2014 09:13PM by machapa.
June 06, 2014 02:29AM
