e3d-v6 assembly June 18, 2014 07:18AM |
Re: e3d-v6 assembly June 18, 2014 07:40AM |
Re: e3d-v6 assembly June 18, 2014 09:29AM |
Re: e3d-v6 assembly June 18, 2014 10:57AM |
Re: e3d-v6 assembly June 18, 2014 10:58AM |
Re: e3d-v6 assembly July 03, 2014 01:00PM |
VIDEO TUTORIAL ASSEMBLING E3D V6|
Re: e3d-v6 assembly July 04, 2014 09:12AM |
createc3d
Hello,
we've made a video-tutorial for the assembling of E3D V6, hope it helps youVIDEO TUTORIAL ASSEMBLING E3D V6
Best Regards
Re: e3d-v6 assembly July 04, 2014 09:36AM |
You just need to change Z home pos - or is the Z carriage physically unable to go lower? If that is the case then it would need a part printed to extend it or alteration of the extruder.Quote
drmaestro
createc3d
Hello,
Best Regards
Hi, I have asked this question in the original topic about E3D however I was unable to get an answer: Can I modify the legth of the E3D? My old hotend measures 78 mm and I cannot use a shorter hotend because my X axis is at the lowest position. If I inserted a shorter hot-end, there would be a gap between the tip of the hot end and the heated bed (I assume this could only be possible if the heat break can be held in place without being fully assembled).
Thanks...
Re: e3d-v6 assembly July 04, 2014 10:37AM |
Re: e3d-v6 assembly July 04, 2014 12:01PM |
Ralph.Hilton
drmaestro
createc3d
Hello,
Best Regards
Thanks...
Re: e3d-v6 assembly July 05, 2014 07:02AM |
