What type of bed spring should I get?
Posted by BradStaff
June 19, 2014 09:04PM
I am very new to 3D printing and plan to use springs on my Smartrap. What would be the best kind to get for my bed?
Re: What type of bed spring should I get?
June 21, 2014 12:35PM
the strongest you can find, and that fit around your bed screws!
June 21, 2014 12:36PM
victorjung
That's super vauge and obvious!
June 21, 2014 05:24PM
yes i know, but there is nothing more than that you should worry aboutsmiling smiley
June 21, 2014 05:36PM
I guess your right, I ordered some that looked strong and fit and I'll see how they dothumbs up
June 23, 2014 05:25PM
Pressa clothes pegs from Ikea have perfect springs.
[3DKarma.com] - suppliers of quality, affordable 3D printer kits and filament for the UK market.
June 27, 2014 11:10AM
The best spring to get is a design that doesn't use springs.
June 30, 2014 10:04AM
tjb1
could you suggest some? Cause I don't remember to have seen any?
June 30, 2014 12:58PM
victorjung
tjb1
It means hard mount the bed...nuts, washer, spacers..anything but springs.
June 30, 2014 05:01PM
You can see my last solution for this in attach.
Plastic dist get less heat down to aliminium support
Easy to adjust height of bed, just loosen the 2 nuts and adjust smiling smiley
Springs seems no point for me. You still have to adjust height proper. No value added with springs .....
Ha det gött
Bosse
Edited 1 time(s). Last edit at 06/30/2014 05:07PM by sidhabo.
Prusa i3 Reworked, Delivered March 28 2014, RAMPS 1.4
Göteborg, Sweden
open | download - HeatBedDist 001.JPG (208.9 KB)
June 30, 2014 05:37PM
The value of having springs is saving your bed if your hot end crashes into it. With springs = bed moves down and no damage done. Without springs = cracked glass / groove dug into the bed / damaged hot end. The end stop should stop the latter happening, but mistakes are known to happen.
June 30, 2014 08:18PM
As someone who destroyed a hot end nozzle by crashing it into an unsprung bed I can attest to the value of springs! I don't feel they need to be that strong (I'm using 4 from pulled apart pens) as the downwards pressure from the hot end should be very small if the z-stop is calibrated correctly. I have way more problems from thermal expansion of the bed than I ever do from the springs not being adjusted correctly... And that's mostly from impatience trying to print before the whole frame/heatbed/glass has got to a thermal equilibrium.
July 01, 2014 07:56AM
3dkarma
No, this concept is enirely wrong. TURN DOWN YOUR Z DRIVER, you do not require that power.
As the person said above, "the strongest you can find, and that fit around your bed screws! ". Now can you tell me why someone would suggest "the strongest you can find"?? Because the bed moves when attached with springs, it wobbles and floats...maybe not up and down, but side to side and forward and back. This is solved by using very strong springs which negate the point of using them.
If you want to make good prints hard mount your bed and turn down your Z axis, they require almost no power on a cartesian because the Z axis does almost nothing.
If you are just printing for fun, do whatever you want...I don't care. Springs are not the way forward, ask anyone with experience.
Edited 1 time(s). Last edit at 07/01/2014 07:57AM by tjb1.
July 01, 2014 08:40AM
My Prusa actually has like failsafe if Z motor feed and hot head hit the glass. The nuts in X axis end mounts just disengage when the X axis assy is lifted off them.
I did NOT warm the nuts into the plastic mounts.
Drawback is you need to readjust Z level if this happens. Since you might not get the nuts in exactly same height when you get them back into mounts.
Still that saved my glass already a couple of times smiling smiley
Ha det gött
Bosse
Göteborg, Sweden
July 01, 2014 06:45PM
tjb1
3dkarma
Calling it "entirely wrong" is a bit strong. It is a reasonable failsafe, especially for beginners. There are many examples of printer designs, created by people with experience, that use sprung beds. For example, Reprappro, one of the oldest in the business, uses sprung beds. Using strong springs doesn't negate their usefulness - the bed will still move before the hotend causes damage.
July 01, 2014 11:06PM
tjb1
3dkarma
It shouldn't wobble and float if the mounting screws are secure and the right size for the holes in the bed. I've got 3mm screws, 3mm holes in the bed, and no lateral movement at all. There's some friction of the screws in the holes so the bed doesn't float up and down as smoothly as it could, but it doesn't need to. It just needs to be easily adjustable, and give enough if a Z disaster happens.
July 02, 2014 07:40AM
3dkarma
tjb1
3dkarma
Being the oldest in the business does not make it right, you would think being this long in the business he would know information required for setup? Take a look at the motors, no amperage rating and no coil diagram(easily figured out though). There was also quite a bit more required information missing on other things but I've not got the time to find them.
Turn your Z drivers down, a cartesian bot does not need Z motors with max current.
Edited 1 time(s). Last edit at 07/02/2014 07:40AM by tjb1.
