Heated Bed Stopping
Posted by mccajoe
Heated Bed Stopping
June 26, 2014 02:13PM
Hello,
The heated bed on my printer stops heating at around 30°C to 39°C, while it is set to heat up to 110°C. Anybody know what might be causing this?
Re: Heated Bed Stopping
June 26, 2014 11:32PM
Did it ever work correctly? Is it still trying to heat? Could be insufficient power to the bed. I'd check the bed terminals for the expected voltage.
June 29, 2014 04:00PM
It did heat up early on, but before the printer was properly calibrated. It is trying, I'm just not sure what is stopping it around 30°C. I'm not at home currently, but I'll make sure to check this when I get back.
July 18, 2014 11:05PM
You might also check whether your electronics are overheating. I had a cracked polyfuse on mine that was tripping at much lower temperatures than it should have and cutting power to the bed.
