I've built the reprap motherboard circuit on a breadboard and uploaded the firmware to communicate with ReplicatorG, but it won't connect. ReplicatorG successfully resets the atmega644p, but it fails to initialize. ReplicatorG says:
Reset.
No connection; trying to pulse RTS to reset device.
Unable to connect to firmware.
I hooked up a second serial adapter to monitor the communication to try to find the problem, and I found that the chip sends "R3G Master v106" back after the reset, but not until a second or two after ReplicatorG says that it's unable to connect.
I have tried both with the 1.6 firmware that ReplicatorG installs and the G3Firmware from github (this one says "start" instead, but has the same problem). What could be causing this? I haven't built some of the components outside the motherboard yet, could this be delaying the startup? Is there any way to make ReplicatorG wait longer for the firmware to boot?
