RAMPS thermistor and endstop connectors
July 14, 2014 03:15PM
Hi folks,
I'm having an issue where the thermistor and endstop connectors will fall off the RAMPS board. I have my RAMPS board mounted 90 degrees on the side of my frame.
The connectors have almost no friction with the pins. I think they slide off just from the vibrations of my printer.
Are there any sort of locking connectors I can purchase? Or other ideas?
Thanks!!
Re: RAMPS thermistor and endstop connectors
July 14, 2014 03:46PM
They should have enough friction to where they won't fall off. If it were me, I'd cut the current connectors off and solder on new ones. Pololu has all the connector housings that you need as well as pre-crimped wires that can be easily inserted into the housings.
July 14, 2014 04:02PM
Let me try the precrimped connectors. Maybe I did the crimping incorrectly.
Thanks!!
July 14, 2014 05:53PM
You may have put the pins in the plugs the wrong way round, it's easy to do, they have a little raised hook that retains them. Pull them out give them a little tweak they should hold the pin.
