Fan wiring???
Posted by kevbme
Fan wiring???
July 31, 2014 10:14AM
I am using a Sanguinololu 1.3a, Marlin firmware and a LCD 2004 control. How would i hook up a fan to my hot end?
Re: Fan wiring???
July 31, 2014 07:36PM
To cool the print or the hotend? For the hotend just wire it to your power supply so it is always on. For the print...not familiar with that board, but my guess would be the output for the second extruder, if it has one and you aren't running 2 heads.
Re: Fan wiring???
July 31, 2014 08:32PM
For the print. There is only 1 extruder output. I would like the option of turning of and on with the slice settings.
Re: Fan wiring???
August 01, 2014 02:53AM
You have to add a external board to control a fan with a Sanguinololu (its the budget controller, nothing extra)
You can buy things like [www.thingiverse.com]
Or you can hack one together like [www.instructables.com]
Re: Fan wiring???
August 01, 2014 06:54AM
Re: Fan wiring???
August 01, 2014 10:28AM
Yes, but my problem is that the LCD 2004 plug takes up ALL 20 of the IO and ISP pins.
Edited 1 time(s). Last edit at 08/01/2014 12:17PM by kevbme.
Re: Fan wiring???
August 03, 2014 09:37AM
This is where the fan gets connected, but the pins are not on my board. Does anyone know where I can buy the male and female ends from?
Re: Fan wiring???
August 03, 2014 10:08AM
I found them.
[www.mouser.com]
[www.mouser.com]
Edited 2 time(s). Last edit at 08/03/2014 10:12AM by kevbme.
Re: Fan wiring???
August 03, 2014 07:40PM
Those are just 12v pins, always on, no firmware fan control.
