Calling all USA 3mm PLA users August 08, 2014 09:02AM |
Re: Calling all USA 3mm PLA users August 08, 2014 11:12AM |
Re: Calling all USA 3mm PLA users August 08, 2014 12:15PM |
MrDoctorDIV
3mm has increased friction naturally, so you're problems are likely to be on the worse end. Filament suppliers also play a role. I've got MatterHacker's PLA [1.75mm] and I have both their standard and their Pro series filament. The cheap stuff actually prints a lot easier, it runs through easily and has never jammed to something that wasn't my fault [forgetting to plug the heatsink fan back in]. The pro series filament, although running buttery smooth and consistent, has increased friction and requires higher temps [which I like, it prevents oozing and prints naturally at a higher quality] and I have had that jam a few times. Not a big deal, I just don't print anything using their Pro filament unattended. I can hear my extruder skip so I know right away and can unjam right away.
It's hit and miss.
Re: Calling all USA 3mm PLA users August 08, 2014 01:34PM |
Re: Calling all USA 3mm PLA users August 08, 2014 02:09PM |
Re: Calling all USA 3mm PLA users August 08, 2014 03:25PM |
Re: Calling all USA 3mm PLA users August 08, 2014 04:42PM |
See this is what im wanting to find out! If the 3mm works then im golden and ill get a spool but if the 1.75 is better then ill look into a new hot end.Quote
amramsey
If I'm not mistaken, the majority of the people having troubles with the E3D v5 and PLA are 1.75mm users. The 3mm PLA has no issues there.
Re: Calling all USA 3mm PLA users August 08, 2014 08:35PM |
Re: Calling all USA 3mm PLA users August 09, 2014 08:57AM |
Re: Calling all USA 3mm PLA users August 09, 2014 09:17AM |
Re: Calling all USA 3mm PLA users August 09, 2014 12:47PM |
