M114 not responding
Posted by polkary
M114 not responding
August 15, 2014 05:00AM
I'm now doing calibration & just noticed that while sending M114 is working OK at start after some trials it doesn't responds.
Has someone else experienced the same behavior or just sent M114 & didn't got response several times?
[while G28 and all motors & other values are functional]
Best regards.
Re: M114 not responding
August 16, 2014 04:39AM
Sounds like a bug in your firmware. Developers should appreciate a bug report with a step by step procedure on how to reproduce it.
August 17, 2014 05:00PM
Thank you for your replay.
Since I just began & still have allot to learn I'm still not sure that I'm not to blame..
I'm not that sure if it is a bug since I got it once & since I've bone that on my windows comp, I've used the regular binaries at the site & not the git hub version which are quite old.
So I've might just encountered this solved issue..
I simply switched version.
