Need diag help! First time RepRap builder August 16, 2014 05:37AM |
Re: Need diag help! First time RepRap builder August 16, 2014 07:24AM |
Re: Need diag help! First time RepRap builder August 16, 2014 01:39PM |
Re: Need diag help! First time RepRap builder August 17, 2014 03:29PM |
Re: Need diag help! First time RepRap builder August 18, 2014 11:11PM |
Re: Need diag help! First time RepRap builder August 19, 2014 12:01AM |
Re: Need diag help! First time RepRap builder August 19, 2014 10:10AM |
Re: Need diag help! First time RepRap builder August 20, 2014 12:53AM |
Re: Need diag help! First time RepRap builder August 20, 2014 01:17AM |
Re: Need diag help! First time RepRap builder August 20, 2014 01:55AM |
sdavi
Also check that you set the right baud rate in repetier host, as that needs to match the rate set in the firmware. Since the firmware was preloaded its hard to tell, but it's most probably going to be 250000 or 115200.
Re: Need diag help! First time RepRap builder August 20, 2014 02:11AM |
boymeetsmill
sdavi
Do I need to change this in the windows device manager too? More specifically on the 'FT23R USB UART' which I believe is the USB Serial emulator.
Re: Need diag help! First time RepRap builder August 20, 2014 02:48AM |
ystem.IO.Ports.SerialErrorReceivedEventArgs
