Lost in the marlin firmware
Posted by polkary
August 25, 2014 01:44PM
Just before printing the test cube I've noticed that my heated bed isn't heating.
When tested I don't get ANY voltage on D8.
My setup: Kossel mini, Arduino mega 2560, Ramps 1.4, bed 170 [mm].
I should have "Kapton Bed Heater" & when testing it's resistance I got 7.7[Ohm]
It's not a power issue since every thing else works smiling smiley ,including 0.2 diff or less on all locations + hot end working.
I'm sure I've missed something on the configuration.h
Please advice what settings should be on & with what value for my heated print bed to work...
Re: Lost in the marlin firmware
August 25, 2014 02:51PM
Have you connect the "two" power inputs on your ramps board? The 11 Amp and the 5 Amp
August 25, 2014 04:06PM
Thank you for returning me back to basic!
I was tired and .... didn't noticed that 1 wire of the 11[A] disconnected.
Now everything is OK.
Thanks!
