What is the cheapest RepRap that I could build?
August 29, 2014 11:30PM
I have a Printrbot, and I love it. I also really want a second printer, but this time I want one that is truer to the RepRap goal (example: printed parts rather than a wood frame). What is the cheapest RepRap that I could build? I could 3D print parts for it if that makes a difference. I am also looking for a good place to get replacement parts like stepper motors for a good price.
Edited 1 time(s). Last edit at 08/29/2014 11:31PM by pisquaredtau.
Re: What is the cheapest RepRap that I could build?
August 30, 2014 01:35AM
How about a Prusa i3?
August 30, 2014 01:48AM
What is the minimum I can pay for this printer using 3d printed parts?
August 30, 2014 02:03AM
Also, is there a complete singular parts list?
woo
August 30, 2014 02:12AM
you can build it for around 200 usd if you use ebay parts.
i got mine for little more but with 3mm ful lasercut frame(no threaded rods on frame, payed 2 beers) and i use e3d hotend wich is little pricier then ebay hotends
you can see it in repprappers forums.
Edited 1 time(s). Last edit at 08/30/2014 02:12AM by woo.
August 30, 2014 02:17AM
Ok. Is this a good value?
August 30, 2014 03:02AM
Well that depends on what you value. Almost everything in that kit could be bought at a hardware store for about 3/4 of what they are charging. But, there is lots of value to having all the parts assembled together for you. In the Time/money/quality equation what is your priority?
Thanks Mike
August 30, 2014 03:11AM
Money is my main priority.
August 30, 2014 04:33AM
In that case I would find a SAE (provided you are in the US) parts list and head down to Lowes/Home depot Parts doing a quick online shopping trip I end up with a total of $60-65 and a lot of extra parts. You will have to source the bearings belts and pullies oneline.
Thanks Mike
August 30, 2014 11:16AM
Smartrap. Around 200. The only downside is that it is very similar to your printrbot.
$200 to build. Folgertech has good prices for parts.
August 30, 2014 07:11PM
Can I get any NEMA 17 stepper motors?
August 30, 2014 07:39PM
I looked at the Smartrap, does not look quite as good as the Prusa i3.
August 30, 2014 08:20PM
Are the hardware kits universal? I see hardware kits for Prusa Mendels without a specific iteration.
August 31, 2014 02:29AM
Is this compatible with the i3? Description says it is for the i2.
August 31, 2014 03:00AM
pisquaredtau
You need to provide us with a link so we can look at what you're talking about.
Thanks Mike
August 31, 2014 03:01AM
Sorry forgot it. [www.ebay.com]
Edited 1 time(s). Last edit at 08/31/2014 03:03AM by pisquaredtau.
August 31, 2014 03:02AM
Miertam
pisquaredtau
Thanks Mike
Sorry forgot it. Here it is: [www.ebay.com]
August 31, 2014 03:23AM
Well sort of. Most of those parts can be used on either printer but the quanties will be off the kit you are looking for is I3 bolt kit.
I would still hit my local hardware store for most of those. I might pay a bit more but when you add in shipping costs and extra time I think i come out ahead.
Thanks Mike
August 31, 2014 03:26AM
Miertam
Thanks Mike
I have tried going to my local hardware stores included Lowes and Home Depot. Whenever I ask for a specific part, they never have it. I think I will get the kit you suggested. Thanks
Edited 1 time(s). Last edit at 08/31/2014 03:32AM by pisquaredtau.
August 31, 2014 03:39AM
I keep seeing the rework frame when looking for parts. Is this the same as the single frame? I know the difference between the boxed and single.
August 31, 2014 11:18AM
pisquaredtau
The original "single frame" design uses aluminium and is 1 piece. Most "rework" frames are the same frame size but are made from plywood, MDF, acrylic etc and have 2 extra braces and 1 longer Y-Frame threaded rod. Unless you know someone with a water jet cutter a plywood/MDF/acrylic laser cut frame will be cheaper. The Z motor mounts and z top pieces will fit either.
With the laser cut frame with braces you will need to make sure the slot in the brace will fit the Y-Frame threaded rod size. The "sgraber" frame is for vanilla Y-Corner pieces that use 8mm, while the "rework" design Y-Corner pieces use 10mm.
Steve
Edited 1 time(s). Last edit at 08/31/2014 11:22AM by SteveRoy.
August 31, 2014 01:45PM
Will these work for the belt?
August 31, 2014 07:51PM
pisquaredtau
Yes, but I thought you wanted cheap:
[www.aliexpress.com]
August 31, 2014 07:53PM
SteveRoy
pisquaredtau
I do want cheap, but I had already ordered those other belts. Thanks. AliexPress looks like a great supplier for 3D printer parts.
Edited 1 time(s). Last edit at 08/31/2014 07:57PM by pisquaredtau.
