Where to get Ramps 1.4 Connectors?
Posted by quillford
September 05, 2014 04:10PM
I am building a Prusa i3, and none of the stepper motors come with connectors? Where can I source all the connectors I need for my build?
Anonymous User
Re: Where to get Ramps 1.4 Connectors?
September 05, 2014 05:09PM
These housings with these crimp terminals (http://ex-en.alliedelec.com/).
September 05, 2014 05:13PM
3dkarma
For just the stepper motors or is this for everything I will need to connect to the board such as the hot end?
September 05, 2014 05:51PM
If you're not into doing your own crimping, you can get these and these and then just solder wire to wire.
September 05, 2014 05:55PM
jbernardis
Perfect. I already have some of those female to female connectors. I have never done crimping before. Is it easier than soldering?
Anonymous User
September 05, 2014 05:58PM
Good video here (youtube.com). It's easier to crimp than solder. The instructional video uses a specialist tool, but with practice you can do it with a pair of needle-nosed pliers.
September 05, 2014 06:19PM
3dkarma
Ok. I think I will try crimping. Thanks
September 05, 2014 10:49PM
I've not had good luck with crimping. Usually the electrical connection is OK, but the connector gets bent to the point where it does not insert easily into the housing. I find it far easier to just work with the pre-crimped wires, but that's me.
September 07, 2014 03:16PM
Soldering is easier. For personal use lead/tin solder is still legal and it is much easier to be sure of good connections. However soldering to hotend componets is best with lead free solder as it has a higher melting point.
September 08, 2014 02:19PM
My first attempt I was the "big man" using needle nose pliers to crimp my ends and a little bit of solder to reinforce it. Complete disaster. Bought an internet recommended rachetting crimper, which cost a little more, but also picked up a bunch of connectors so it likely all worked out when you factored in shipping. So now all my electricals are working so much better.
