Let out the Magic Smoke September 11, 2014 01:11AM |
Re: Let out the Magic Smoke September 11, 2014 02:06AM |
Re: Let out the Magic Smoke September 11, 2014 04:46PM |
Re: Let out the Magic Smoke September 12, 2014 01:03AM |
Re: Let out the Magic Smoke September 13, 2014 02:09AM |
Re: Let out the Magic Smoke September 13, 2014 04:54AM |
waitaki
What is "magic" about smoke?
Re: Let out the Magic Smoke September 14, 2014 03:06PM |
Re: Let out the Magic Smoke September 17, 2014 09:04AM |
Re: Let out the Magic Smoke September 17, 2014 09:34AM |
Re: Let out the Magic Smoke September 19, 2014 03:41AM |
Re: Let out the Magic Smoke September 20, 2014 03:30PM |
stustu242
I don't know if I should start a new thread or attempt to hijack this one.
Anyway, I have a problem with my heated bed. I believe it is drawing to much current from my PSU. After running it for a bit, I saw some "magic smoke" appear from behind the printer. I pulled the plug and saw that one of the PSU plugs had melted. I felt the wires and they were very hot (the wires going to HB-PWR on the RUMBA board). Luckily no melting on the expensive RUMBA board. Am I correct in assuming that this heated bed i purchased (a very cheap no brand) has too little resistance, thus causing high current draw from the PSU?
PSU is a very cheap generic one for a PC although probably does about 400W. I don't think this is the problem though because i have a second printer running fine from a even cheaper PSU, but a more expensive heated bed.
I am thinking about just buying from a more trustworthy source a second heated bed, unless someone could help me solve this problem if there is a simple solution.
Thanks
Re: Let out the Magic Smoke September 25, 2014 01:02PM |
