Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 24, 2014 09:55AM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 24, 2014 06:02PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 26, 2014 08:44AM |
cozmicray
The big message
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 26, 2014 08:59AM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 26, 2014 02:41PM |
dougal1957
[T]hey are called DUPONT Connectors and they come in a variety of sizes
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 27, 2014 03:17AM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 29, 2014 08:41PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 29, 2014 08:54PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 29, 2014 09:14PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 30, 2014 04:07AM |
cozmicray
Yes I have the Arduino Mega 2560...
I can see that the unit is powered by the USB fine, but if I connect the ATX 12v (I diced up the 2x2 4-pin 12v rail), it doesn't get powered up, probably due to D1.
I would NOT install D1 and run arduino on usb and RAMPS on your external power supply
I think that you need 5V to run Arduino --- and there is NO 12v to 5v converter
I don't know if Arduino likes 12V
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 30, 2014 03:01PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 30, 2014 03:18PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 31, 2014 09:08PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers October 31, 2014 10:54PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 01, 2014 07:39PM |
dailafing
It's ironic that people are asking me to read up on things, when it seems that some people are unable to read themselves.
Can somebody tell me exactly where I have asked what "shielded cable" is?
I do, however, recall asking for an example where shielded cable has been used on such a low-voltage setup.
I believe the chances of inductive interference, or potential crosstalk is minimal on a scale where such low voltage such as as 12V is being used.
ok, I'm going to need some examples from you in relation to what wiring your referring to....?
Shielded wiring? on this small scale? Gonna need to see some examples...dailafing msg October 26, 2014 08:44AM
A printer ,now no longer made, where endstop wires (unshielded) were run close to Stepper Wires (unshielded) and caused all kinds of endstop trips.
Lots of power (Amps) going to stepper coils at high frequency --- causing crosstalk!
Just a suggestion to use shielded wire from experience to keep you out of trouble.
But sounds like you are RF engineer and will use any wire that is available?
Anyway, I just spent another £100 on parts today, and also been talking to another mate who's going to be getting some 12mm bars for me soon.
Someone mentioned above about the X rails (1500mm) may need linear movement support on both sides of the rails. I've taken this on-board and I'm having an additional plate installed on the other side of the x-axis closest to where the user would stand, just in case an issue arises. Then I can just install another name 23 on that support, should I run into any issues were straight out on the single motor. I can just install stepless book the table and have the single controller run both maltose.
Above paragraph needs translation:
Again I'll say testing showed 12mm diameter 36" in length solid rods flexes a lot. up/down, side to side, even under tension!!!!!
You are going to have 10 pounds (extruder hot end, extruder, extruder motor) wizzing around out there in the middle of 4 long rods.
If you are going to use a bowden --- my condolences and be prepared for MAX frustration!!
But you are the phd mechanical engineer -- designing this HUGE printer with precise resolution!
My tested Rod is:
17-4 PH Stainless Steel Round Rod 12 mm
17-4 Precipitation Hardening (PH) Stainless Steel combines high strength with corrosion resistance.
The alloy is also known as 630 Stainless. 17-4PH has approximately the same heat and corrosion resistance as the 304 alloy.
Material: Stainless Steel
Alloy: 17-4 Stainless
Shape: Round Rod
Diameter: 12mm
Condition: H900
Finish: Turned, Ground and Polished
Hardness: RC 45-47
Notes: Tolerances: Diameter: (+0/-.0005) | Length (+/- 1/8")
Do you think that a single controller on the ramps board will be able to power two motors?
Also, are there alternative or more powerful stepper motor controllers that I could have purchased for use with my ramps board?
My Ordbot Hadron has TWO Z-Stepper motors (Nema 17 12V) run on one RAMPS driver and it runs fine.
Can't say anything about NEMA 23 motors or 24V.
If you have to go to a driver for each motor then I suppose dual extruder is out -- drivers used for axes drive
More powerfull stepper drivers would be off the RAMPS board but I suppose wires from RAMPS drivers can be run out to other drivers.
Might as well use the RAMPS and when it doen't work you can spend more money for controller and drivers that may work.
While you are replacing the rods because of too much flex and bad hotend resolution.
Keep going at high speed, not looking at other designs, or some suggestions --- and your going to have a lot of re-building
but I guess that is prototype development??
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 02, 2014 08:35AM |
dailafing
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 02, 2014 10:24AM |
Iceman086
As long as your stepper drivers are rated for 2 amps and your motors are only 1 amp a piece then you will be fine. But if you go with larger steppers that draw higher amperage then you won't be able to run two of them off of one driver.
Likewise, if you want to get a higher grade stepper drivers, you can go with Pololu Black's. They are rated at 2.3 amps but require active cooling (a fan and heat sinks) to run at full capacity. Otherwise you can use standard stepper drivers to send the signals to a larger, higher powered stepper driver which will handle pushing the power needed for multiple motors.
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 03, 2014 12:04AM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 03, 2014 01:32PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 03, 2014 01:49PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 03, 2014 02:08PM |
cozmicray
You are building a huge printer
but
NOT scaling up everything.
Your huge prints will require days of printing
Will your electronics, motors last for days without melting?
Your X, Y. Z movements will be 4 times smaller printers
thus motors running longer and harder.
Long suspension of your extruder on tiny rods will kill the resolution.
Big printers need big motors, big electronics, big mechanics
and thinking of all the things BIG changes of a little printer?
ABS printers a usually enclosed -- keeping production chamber warm
--- are you going to put your printer in a huge powder coating oven?
Matchbox car vs real car???
Just a thought
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 03, 2014 03:35PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 04, 2014 06:15PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 05, 2014 09:22AM |
Paul Wanamaker
Hi People!
Lots of great input here. Good luck with the build.
I am finishing a large format printer and I have a few thoughts about mariechuria's comment.
Heating the chamber is no problem, the heated bed will do that all by itself nicely.
You will of course want to have the electronics and motors outside the chamber if possible. A delta printer makes that a bit easier.
Power consumption is not bad if you have insulated well. I used 1/2" R-matte Plus 3 from Home Depot, as it can handle the heat.
I watched the Kayak printing video. Very nice. With heated chamber and proper temperature the layers should be well adhered. I'd like to know his perimeter width and infill settings...
Note that building larger means much more mass, and so you must have slower accelerations to not miss steps, which adds to print time. I had this problem with Raptosaur - I cut the acceleration down to 650 and that fixed my lost steps issues. I may be able to accelerate faster, we'll see.
For larger jobs there needs to be a filament-out sensor and firmware that will detect it, or you can set something in your slicer to pause at a certain height (Cura has this under Extensions).
I know Repetier is planning on supporting a filament out sensor in future, not sure if others have it! I am planning on some jobs that will take more than 1kg of filament, I may combine rolls.
For safety I added two mechanical thermostats - one on the heated bead, and one in the chamber in series - if either trips the heat bed is off. The thermistor in my hot end is well secured, so I'm not worried about that.
I used .9 degree high torque Nema 23 steppers from Phidgets for everything including my direct drive extruder. These run fine on common drivers, even though they are rated for more current. I have small quiet fans on all the steppers so they remain cool.
I recommend planning and modeling everything entirely before starting.
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 05, 2014 12:17PM |
New here and just lurking as I consider a RepRap project, but I feel the need to chime in on the above comment.Quote
dailafing
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 05, 2014 12:40PM |
dclarkm
dailafing
Stepping motor control is done via relatively high currents and THAT is what causes crosstalk between adjacent wires (fast current changes). Assuming you won't get interference because the voltage is 12V speaks volumes about this thread in general.
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 05, 2014 01:17PM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 05, 2014 03:11PM |
cozmicray
What is this suppose to mean?
I recommended the use of shielded wires for both stepper and endstop switches
because there WAS a real problem in a printer build
AND It is a GOOD practice to use good wiring on LONG wire runs.
Just because dailafing is bumbling along with his printer build
doesn't make the thread bad.
One doesn't know if a thread post is from an expert or a boob!
Beware of responses --- do some surfing / study on the topics?
Are you an RF/ electrical power engineer?
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 09:32AM |
Re: I'm Thinking Of Building My Own Large Scale 3D Printer, And I'm Looking For Some Advice On Part Choices, And Advice On Overstraining Familier Parts From Smaller Printers November 06, 2014 12:46PM |
