Extruder motor not responding
October 06, 2014 02:48AM
Hello,
I am using Prusa i3 3D printer.
When I extrude manually some filament from extruder using Pronterface, the extruder motor does not respond.
Does anyone had this issue?
Regards,
Prashant.
Re: Extruder motor not responding
October 06, 2014 02:22PM
Is it plugged into the correct spot on the board?
Are you connected to the printer in Pronterface?
Is your hot end heated up?
Can you move using the manual controls?
Is your current set properly?
greghoge.com
HUGE 3D PRINTER PARTS SALE!!!
October 06, 2014 02:37PM
hi,
I have done it correctly everything you mentioned.
Also I swapped the pololu drivers and checked, but no success....
Regards,
Prashant.
October 06, 2014 08:14PM
Try switching the extruder motor with either the X, Y, or Z motor and see if it will turn when you use the respective manual controls.
oh, and also double check to make sure you have it set up with the correct pins the your firmware.
greghoge.com
October 07, 2014 01:07AM
I tried switching themotors.... it works fine. Motor is not at fault.
I even tried switching another pololu driver, still it does not work.
Any changes to be made in pins.h file for ATMEGA2560, marlin firmware?
October 10, 2014 08:17AM
I have a similar problem too. But i connected the extruder motor to the Y-axis pins on Ramps and it works just fine.
So atleast the motor works alright.
Have you tried varying the potentiometer? Sometimes the current being supplied to the motor may not be sufficient to get it working
Edited 1 time(s). Last edit at 10/10/2014 08:18AM by gnex16.
October 10, 2014 08:22AM
The motor works when connected to X, Y axis.... also it does when connected to E0/E1 but response is delayed....
It rotates with some time lapse....
Regards,
Prashant.
Re: Extruder motor not responding[closed]
January 07, 2015 06:00AM
Changed RAMPS board....
