RS485 questions
Posted by eustace
RS485 questions
April 05, 2010 09:07PM
The continued unavailability of the SN75176 chip is keeping me from completing my electonics, so I started looking for a replacement part. I found a Sparkfun SP3485 breakout board, and I thought I might be able to use it to provide communications for my protoboard Extruder Controller, but then I noticed that the chip is wired differently, with /RE tied to DE. When I compared this to the Motherboard and Extruder Controller schematics, and reviewed the SN75176 and SP3485 datasheets, I got confused. Why is /RE tied high??? Wouldn't that disable the chip? And has anyone else successfully substituted an SP3485 for the SN75176 chip?
Re: RS485 questions
April 08, 2010 01:27PM
eustace,
What country are you in? In the US, digikey seems to show no shortages, under a buck/part in quantity 1.
[search.digikey.com]
If you're in a bind on this, send me a PM and I'll see if I can help you out.
Larry Pfeffer,
My blog about building repstrap Cerberus:
[repstrap-cerberus.blogspot.com]
Re: RS485 questions
April 08, 2010 01:35PM
Oops!
I see that the soic package is out of stock at digikey,
but mouser has some in stock in soic-8:
[mouser.com]
Or you could still buy a DIP8 version,
(digikey shows over 10K in stock): [search.digikey.com]
put it on some perfboard, and tack on wires to connect. Tedious, but probably faster than revising the ckt to use a different chip.
Larry Pfeffer,
Re: RS485 questions
April 12, 2010 10:06PM
For a while, there, neither had the soic part. I'm ordering a dip part for the protoboard extruder controller. My confusion over the pinout was just self-inflicted - I needed to take a closer look at the schematic.
But the breakout board SP3485 came in handy. It really is a drop-in replacement if you have a 5V circuit (or so I'm told) so I removed it from the breakout board and put it on my motherboard, which is now complete and functional.
