Z-605 kit has bad 3d printed parts. October 10, 2014 09:31PM |
Re: Z-605 kit has bad 3d printed parts. October 13, 2014 03:06PM |
Re: Z-605 kit has bad 3d printed parts. January 14, 2015 11:33AM |
Re: Z-605 kit has bad 3d printed parts. January 20, 2015 02:44AM |
Re: Z-605 kit has bad 3d printed parts. February 02, 2015 05:52AM |
Re: Z-605 kit has bad 3d printed parts. February 02, 2015 04:52PM |
Re: Z-605 kit has bad 3d printed parts. February 02, 2015 09:39PM |
Re: Z-605 kit has bad 3d printed parts. August 16, 2015 08:30PM |
elwood127
Hey Willy, I have kit STL's from the seller. I reprinted my motor mounts and they came out pretty darn straight. You are welcome to the files. Let me know. Brian.
Re: Z-605 kit has bad 3d printed parts. August 17, 2015 02:17AM |
Re: Z-605 kit has bad 3d printed parts. August 17, 2015 08:20AM |
I copied the DVD content to my tablet and I have the complete 'support package', presentation files, spreadsheets, videos, in front of me on the workbench. The assembly guide, to be used together with the individual videos, simply stops identifying the actual fixing specifications. There are several 'M' series fixings, M3 for example. But the lengths are for M3 the most varied. So to use the wrong length for an early sub-assembly will ultimately leave you without that key component at a later stage for which there is no functional alternative. The whole assembly has to be de-constructed to release the key fixing for another alternative. I have used M3x12mm with 3 spacers, finished by an M3 spring cushion and an M3 shim held together by an M3 nut. This gives adequate clearance to all the other fixings for the hot bed base to the guide rail slide bearings and the thermistor underneath the hot bed. This looks OK but without any clear guidance from the assembly instructions and with the knowledge that I have critically limited resources to complete the overall construction.
Re: Z-605 kit has bad 3d printed parts. August 17, 2015 11:07PM |
Re: Z-605 kit has bad 3d printed parts. August 19, 2015 12:28AM |
Re: Z-605 kit has bad 3d printed parts. August 20, 2015 12:36AM |
Re: Z-605 kit has bad 3d printed parts. August 20, 2015 12:59AM |
Re: Z-605 kit has bad 3d printed parts. August 20, 2015 02:08AM |
the_digital_dentist
Dumb question: Did anyone check to see if the X axis rails were inserted into the Z axis parts to the same depth?
Re: Z-605 kit has bad 3d printed parts. August 20, 2015 06:46AM |
Re: Z-605 kit has bad 3d printed parts. August 20, 2015 10:57AM |
Re: Z-605 kit has bad 3d printed parts. August 20, 2015 08:00PM |
Re: Z-605 kit has bad 3d printed parts. August 21, 2015 06:49PM |
because the kit contained defective parts. Ironically, a shared view, they too were 3D printed. But the printer, used commercially, to 3D-print critical Aurora parts, had not been checked for squared geometries. 3D-printed contributions by members with good ideas have helped others to get their printers set square and working properly, quickly! I think this process will be continued for as long as it is needed and handed on to other members to continue for as long as they are needed.
