Heatbed not working October 16, 2014 02:13AM |
Re: Heatbed not working October 16, 2014 05:24AM |
tanner331
Hi
I have just finished my 3d printer and the heatbed will not heat up. I was wondering what I should do to try to fix it?
When turn on the heatbed on the repetier it says the temperature that it is set but the heatbed doesn't heat up.
It is registering a temperature from the thermistor.
I have tried removing the fuse and replacing it with a wire and that did not do anything.
I have a 20amp power supply to power the 11amp side of the ramps board, there is a separate 16 amp power supply for the other half of the ramps board.
The heatbed is a mk2b PCB heatbed, I did a test of the resistance and it is 0.8ohms.
I do not have the LED hooked up on the heatbed.
I have tried everything I can think of.
Thanks for your help
Tanner
Re: Heatbed not working October 16, 2014 11:05AM |
Re: Heatbed not working October 16, 2014 01:53PM |
tanner331
Would it be in the Repetier software settings or the marlin firmware? Where is the spot to enable the heatbed?
thanks
Tanner
Anonymous User
Re: Heatbed not working October 16, 2014 05:09PM |
Re: Heatbed not working October 16, 2014 06:40PM |
Re: Heatbed not working October 22, 2014 03:15AM |
Re: Heatbed not working October 23, 2014 07:07AM |
Re: Heatbed not working October 24, 2014 03:20PM |
Re: Heatbed not working October 27, 2014 10:02AM |
