Prusa I3 'Eboti' Kit - Having trouble
Posted by vmarcano718
October 31, 2014 07:56PM
I have built the kit. i have the repetier host software on the computer. everytime i try to use the software to turn on the hotbed or extruder the connection resets and i have to reconnect.
here is my info.
melzi board 2.3
[www.elecfreaks.com]
Prusa I3 'Eboti' kit
Repetier Host v1.0.6
Power supply measures :
Input 124v
Output 12v
I noticed that when i short the extruder or hotbed terminals i get the same results - as though the actual devices are connected.
Re: Prusa I3 'Eboti' Kit - Having trouble
November 01, 2014 08:27AM
What does the kit vendor say?
November 01, 2014 10:30AM
They haven't responded.
I am going to order a Ramps 1.4 board but waiting to see if i find a solution before I do.
Edited 1 time(s). Last edit at 11/01/2014 10:30AM by vmarcano718.
Anonymous User
November 03, 2014 05:33PM
Can you disconnect the heated bed from the board and check its resistance? If there's a short it may be causing the reset. Same for the hot end.
November 05, 2014 08:35PM
Resistance:
Hotbed - 1.5 to 1.8
Extruder - avg 4.6
January 27, 2015 05:56PM
Problem solved.
The power supply was set to 220v - my wall voltage is 120v. All i had to do was swtich it.
