Steps Lost November 01, 2014 04:35PM |
Re: Steps Lost November 03, 2014 12:55AM |
Re: Steps Lost November 03, 2014 06:54AM |
Re: Steps Lost November 03, 2014 08:21AM |
Paul Wanamaker
Hi there Gabriel
That's a lot of steps.
I think it's one of the following:
1 - Like you mentioned (and you have a fan now) a stepper driver may be doing a thermal reset. Less likely now that you have a fan on it. Make it a strong fan. When I had this problem it was about a second reset on one driver.
2 - The print head may be hitting. You didn't mention what kind of slicer you use, but in Slic3r there is a setting called Lift Z on the Printer, Extruder 1 tab. This lifts the head slightly when a retraction is called for, and can help things print smoother. Try half a layer eight.
3 - You did not mention your acceleration settings. I had many problems with missed steps because of too much acceleration. Try reducing the acceleration by 3/4 and see if that fixes it. If it does then you can increase your speeds, and slowly increase the acceleration. I think this is the most likely problem.
4 - Jerk setting. Normally this defaults to 20, try reducing to 17. You do not want to lower this too much tho.
5 - Make sure there is a flat ground on the steppers, so the pulleys do not slip. You can also draw a line on the shaft to the pulley to see if it is slipping.
6 - Belts are tight?
7 - Make sure the wiring for the end stops is not next to the stepper motor wiring - could cause the end stops to trip.
8 - Make sure nothing is binding.
-Paul
Re: Steps Lost November 03, 2014 08:30AM |
dave3d
aleatory? I had to look that word up.
I have just been through a similar problem with my printer. As well as the above advice, use a meter to set the stepper voltages.
Also it may be your computer. It was with mine. You can set the slicer program to high priority in task manager and don't do anything else at the same time, like surfing the web. If you can, run the printer direct from an SD card.
Re: Steps Lost November 03, 2014 12:18PM |
Re: Steps Lost November 03, 2014 06:30PM |
Paul Wanamaker
Gabriel,
I recommend getting an LCD with an SD card slot. You will have much more reliable printing, and you computer does not have to be dedicated.
Note that it would be pure luck if your firmware ran your printer well as-is. The person who posted up the firmware very likely had a different setup.
For all major firmware flavors you can adjust the acceleration settings in the Configuration.h, and recompile/upload using the Arduino environment.
Some firmware (like Repetier which I use) allow you to change most of the acceleration settings using the LCD.
For more help you will need to list:
- What kind of printer you have
- What controller board
- And what Firmware name and version.
- You can also attach your configuration.h. Someone here will be able to suggest some reasonable values for acceleration.
He only told me to replace the stepper drivers, but it didn't work. |
Re: Steps Lost November 03, 2014 07:03PM |
Re: Steps Lost November 04, 2014 02:34PM |
Re: Steps Lost November 04, 2014 04:43PM |
Re: Steps Lost November 04, 2014 06:49PM |
dave3d
Gabriel, I have the same Arduino as yours. Check your stepper driver voltage settings first so that can be eliminated. It is easy to do but needs a digital voltmeter. Are your motors NEMA 17?
Re: Steps Lost November 04, 2014 06:51PM |
Paul Wanamaker
Gabriel,
The symptom you are describing is exactly what happens when a stepper driver does a thermal shutdown. That axis misses a bunch of steps.
One of mine (extruder) was doing that this morning for instance. It was sitting still (preheating) and I heard a clunk sound about every 15 seconds. I pulled on the filament and waited a few seconds, and when it happened again I could move the motor freely. Ah! So I just turned the current down a bit on that driver until that stopped happening.
Does it always happen with the same axis, X or Y?
If that does not work, since you have socketed drivers, you can switch them, between x and y for instance (make sure power is off first), and then see if the problem follows the driver.
A driver may just have gone bad.
Or turn down the current even more on the axis that is misbehaving.
That's all I can think of.
-Paul
Re: Steps Lost November 04, 2014 07:11PM |
Re: Steps Lost November 04, 2014 09:57PM |
Re: Steps Lost November 05, 2014 09:32AM |
Paul Wanamaker
Gabriel,
Perhaps someone here that has your model printer can compare the configuration.h. I doubt that's it since your printer was working, and now not, with no firmware or hardware change.
Good idea to try new drivers.
While you're waiting for them, since you've tried lower current, and now it's failing in 2 directions, try higher current (clockwise a bit).
Re: Steps Lost November 05, 2014 04:17PM |
gabgomez
Yes, the motors are Nema 17. What voltages values should I spect to find? I moved the trimpot and found different values according to the power the steppers were taking.
Re: Steps Lost November 05, 2014 05:35PM |
Re: Steps Lost November 05, 2014 06:24PM |
Re: Steps Lost November 06, 2014 05:09AM |
Re: Steps Lost November 06, 2014 05:57AM |
Re: Steps Lost November 06, 2014 03:52PM |
Re: Steps Lost November 06, 2014 05:39PM |
Re: Steps Lost November 07, 2014 01:17PM |
Re: Steps Lost November 07, 2014 02:38PM |
