Z lead screw bottom support for new build November 13, 2014 05:58PM |
Re: Z lead screw bottom support for new build November 14, 2014 04:44AM |
anvoice
I'm designing a new printer, and trying to figure out how to mount my z axis. Using a motor on top and an 8mm lead screw secured with an 8mm coupler, so the bottom end will be dangling down. I do plan to install a bearing mount, but I'm wondering if there's a need to actually support the screw from the bottom, since all that's holding it in place is that coupler grub screw? If so, are there any good designs for such a support? Seems like it would need to rotate with the screw, so perhaps something based on a bearing, like a bearing with the hole blocked off?
Re: Z lead screw bottom support for new build November 14, 2014 02:24PM |
Re: Z lead screw bottom support for new build November 15, 2014 02:54AM |
anvoice
Thanks, that seems very usable.
As far as the piece of metal goes, wouldn't it impede rotation if the metal can't rotate with the screw? That's why I thought about something like a piece of metal actually attached to the center portion of a bearing, so that it could spin, but I doubt I could make something like that unless premade ones are sold.
Re: Z lead screw bottom support for new build November 15, 2014 08:29PM |
Re: Z lead screw bottom support for new build November 15, 2014 08:49PM |
dougal1957
You could put that pieces of metal on a thrust bearing Something like this that would work in fact you wouldn't need the piece of metal just make sur the end of your rod is flat or maybe even have the end turned down to fit the centre of the bearing (or put a cone point on the end of it).
Doug
cozmicray
Having a free end on your Z-axis lead screw is OK,
anything else may constrain it too much.
cozmicray
The lead nut -- attached to the table or Z-lift
should be a zero-backlash nut
cozmicray
The SolidDoodle, DaVinci, Ordbot 3D printers use un-constrained z-axis leadscrew
cozmicray
Will there be guides on Z-Axis to provide for precision non -rotating lift?
Re: Z lead screw bottom support for new build November 17, 2014 06:02PM |
Re: Z lead screw bottom support for new build November 17, 2014 09:14PM |
Re: Z lead screw bottom support for new build November 18, 2014 08:02PM |
Re: Z lead screw bottom support for new build November 19, 2014 04:43AM |
Re: Z lead screw bottom support for new build November 19, 2014 01:02PM |
Re: Z lead screw bottom support for new build November 19, 2014 08:15PM |
Zavashier
Jo Prusa is right with it's i3 Z conception. You don't need to maintain the leadscrew ont it's end until you don't reach the critical speed, start point when the screw stars to wobble.
cozmicray
A printer like the Ordbot Hadron and others
[www.buildlog.net]
Coupler anchored into motor shaft by two screws
perhaps with cones into shaft
and two screws into leadscrew flats
Should support a ton without coming apart?
Constraining the leadscrew will give you problems
Constrained at coupler, drive nut, and bottom support,
without precise alignment -- binding
Float the bottom support (allow it to move around in X, Y)
