Home built printer with Y axis problems November 19, 2014 11:36AM |
Re: Home built printer with Y axis problems November 19, 2014 11:42AM |
Re: Home built printer with Y axis problems November 19, 2014 11:55AM |
Re: Home built printer with Y axis problems November 19, 2014 12:06PM |
Re: Home built printer with Y axis problems November 19, 2014 12:15PM |
Re: Home built printer with Y axis problems November 19, 2014 12:39PM |
[email protected]
Yes, I've checked the wiring, everything is OK. Here's the link to a short video, which was made after another setting in Marlin, namely the steps/mm. but this is the best I can bring out of this axis and it's making me mad
[www.dropbox.com]
Re: Home built printer with Y axis problems November 19, 2014 12:48PM |
Re: Home built printer with Y axis problems November 19, 2014 01:03PM |
Re: Home built printer with Y axis problems November 19, 2014 01:24PM |
Re: Home built printer with Y axis problems November 19, 2014 05:27PM |
Re: Home built printer with Y axis problems November 19, 2014 07:41PM |
Re: Home built printer with Y axis problems November 20, 2014 01:53AM |
yes, the motors are spinning without the belts on, so do when i load a test file on the board, that one that moves every axis 5mm-s. But when i load marlin, the y arriage won't move, just the way you can see in the video. Maybe user A2 is right and because it is rackling it cannot move parallel both sides...
Re: Home built printer with Y axis problems November 23, 2014 08:40AM |
Re: Home built printer with Y axis problems November 23, 2014 09:31AM |
Admin Registered: 12 years ago Posts: 3,096 |
Re: Home built printer with Y axis problems November 23, 2014 10:00AM |
After playing more with default acceleration settings and default max feedrate settings, the axis moves as it should almost...mainly I've got firmware setting problems now. By the way if you put the whole X&Y axis on LM20UUB bearings and stainless steel rods, it should move like charm, so it does. Now I only hope to get the right settings...
