E3D v6 Mount for Greg's Extruder November 23, 2014 09:26PM |
Re: E3D v6 Mount for Greg's Extruder November 23, 2014 09:44PM |
Re: E3D v6 Mount for Greg's Extruder November 23, 2014 09:53PM |
Re: E3D v6 Mount for Greg's Extruder November 23, 2014 09:57PM |
Re: E3D v6 Mount for Greg's Extruder November 23, 2014 09:58PM |
I will try to get a good one. I have been unsuccessful so far as I have been using my phone as a camera and the extruder is printed in black. I will try to get something distinguishable.Quote
AquaticsLive
What does you printer look like?
Maybe a quick picture would help.
I have scoured the sites as well found few good ideas, but may need to be modified to use on your printer. If you give me an idea of what you would like I can draw one up for you quick in cad or convert one. My printer has a metal case with a nice lip on it, so I made a rather simplemount for the stepper motor, but looks nice; little shelf in each corner to mount the extruder at the optimum location for the bowden tube to mount to. The hothend mounts for E3D can be a bit tricky with the need a spot for the cooling fan.
Re: E3D v6 Mount for Greg's Extruder November 24, 2014 09:32PM |
Re: E3D v6 Mount for Greg's Extruder November 24, 2014 09:34PM |
Re: E3D v6 Mount for Greg's Extruder November 24, 2014 10:13PM |
Re: E3D v6 Mount for Greg's Extruder November 24, 2014 10:20PM |
I want to get direct working first. I have no experience with Bowden.Quote
AquaticsLive
I print Ninja Flex with my bowden, actually it prints it a little better with bowden, and I can run it a little faster. Not sure if you have tried it, but with my direct drive I set all the speeds at 15mm/s in slic3r and worked good, it was a suggestion I found online. Now with my bowden I print it at 20mm/s not great speed, but it really prints nice which is always my goal.
The less weight on the printhead really makes a big difference in how even the layers are; less ripples in the printed wall. Also the All metal hotends make the extruder motor get really warm even with fans.
Swapping filiments with direct drive is much easier though I understand that. I have one direct drive design I will have to redraw because I lost the files, but essentially the stepper motor mounts to the x-carriage with the bottom two screws and the top two hold a pinch arm and guide for the filament really simple and clean.
Link to DropBox old x-carriage
Link to extruder
The extruder pic, if you remove the piece the the bowden tube is connected it bolt right on to the top of the orange X-carriage. I can swap it back and forth depending on what I am printing.
I also have a dual design of that one just snaps off the LM8UU bearings to swap them back and forth, but with the dual one there is no room to mount the extruder motors so when I use that one its bowden only, which really is necessary when you have two the heat gets way to high for the motors to live very long.
Re: E3D v6 Mount for Greg's Extruder November 24, 2014 11:59PM |
I hope these are clear enough. The hot end goes into the hole in the greg's extruder, but there is nothing to keep it held up.Quote
AquaticsLive
Re: E3D v6 Mount for Greg's Extruder November 25, 2014 02:56AM |
quillford
AquaticsLive
Re: E3D v6 Mount for Greg's Extruder November 25, 2014 09:21AM |
Re: E3D v6 Mount for Greg's Extruder November 25, 2014 12:47PM |
I did drill a hole to allow the tubing to go up to the Hobbed bolt. For mounting, did you simply drill holes were it would hold the hot end?Quote
dougal1957
quillford
AquaticsLive
I have one like that and you don't need to print anything for it I will post a pic of mine a little later!
You will need a M5 Washer to fit above the E3D oh and if your Wades body hasn't been modded it helps to drill out the lower Filament guide hole to 4mm (Or 4.1) so that you can run some PTFE Tube (4mm od 2mm id for 1.75mm filament) straight thru the whole assembly shape the top to slope same as the wades body. you then hold the E3D to the body with 2 M3 screws which you will see in my Photo when I post it!
HTH
Doug
p.s. Found this on E3d's website E3D V6 mounting plate
Re: E3D v6 Mount for Greg's Extruder November 25, 2014 01:01PM |
quillford
dougal1957
quillford
AquaticsLive
HTH
Doug
Re: E3D v6 Mount for Greg's Extruder November 25, 2014 01:15PM |
Re: E3D v6 Mount for Greg's Extruder November 25, 2014 08:02PM |
I found them. I am trying to mount it, but I am having trouble keeping the hot end straight.Quote
dougal1957
quillford
dougal1957
quillford
AquaticsLive
HTH
Doug
No need they were already there and they appear to be on yours to but can't be certain as pic is a little blurred they are for M3 screws on mine.
Doug
Re: E3D v6 Mount for Greg's Extruder November 26, 2014 02:59AM |
quillford
dougal1957
quillford
dougal1957
quillford
AquaticsLive
HTH
Doug
Doug
Re: E3D v6 Mount for Greg's Extruder November 30, 2014 04:42PM |
I got it printing perfectly without the washer. Thanks. So far I have reached 110mm/s.Quote
dougal1957
quillford
dougal1957
quillford
dougal1957
quillford
AquaticsLive
HTH
Doug
Doug
I had the same issue until I got some Bowden adapters for my Wades and they came with thin (About 0.5 mm or so) flat washers prob an M5 or M6 put one of them above the E3D (Over the PTFE tube) having first removed the plastic tube retainer from the E3D heatsink.
Then make sure the retaining screws will go thro the wades past the mount hole so that they are supported both side of the hotend and it should be pretty solid mine is but wasn't without the washer I may have a spare washer thinking about it that I can Measure and give you exact sizes i'll see if I can find it later and will modify this post with details!
Doug
edit washer is 15x5.3x1.3mm which looks to be a M5 Penny Washer one of these above the E3D v6 firms it up nicely.
