Anonymous User
Re: Speed November 26, 2014 06:57PM |
Re: Speed November 28, 2014 01:43PM |
Re: Speed November 28, 2014 09:56PM |
Re: Speed November 29, 2014 12:10AM |
Re: Speed November 29, 2014 03:06AM |
mk3a
I've never been able to print faster than ~20mm/s. I have calibrated my extruder steps in the Marlin firmware. My slicer settings have an extrusion multipler of 1.
I don't see how it could be clogged. It will print; it just won't print quickly.
I suspect a problem with the bowden extruder, not the hot end. Maybe I will disassemble the hot end just to have a look and make sure.
dougal1957
You say you have an Airtripper what motor is on that and which drive gear this is what I believe is critical in getting this to work.
see Airtrippers V3 Extruder
Sounds like you need high torque motors for these to work effectively.
I will watch this thread carefully to see how you get on as I am considering Airtripper's for my in progress 4 head printer.
Doug
Re: Speed November 29, 2014 11:28AM |
mk3a
dougal1957
Doug
The motor is: [www.kysanelectronics.com]
The drive gear is MK7.
Here is where I got it: [www.ebay.com]
How much does layer height affect speed? I'm printing at 0.2 mm/layer.
dougal1957
What Hot end are you using everything I read on Airtrippers page suggests that with your setup it should be fine and if not to start looking towards the Hot End.
HTH Doug
Paul Wanamaker
[*] Put marks on the filament with a pen, and across the end of the drive gear. Then watch both while its making that grinding noise to confirm it's the filament slipping.
Re: Speed December 31, 2014 07:39PM |
Re: Speed January 01, 2015 08:09PM |
