Auto Bed leveling Folgertech Prusa I3 question December 06, 2014 12:53PM |
Re: Auto Bed leveling Folgertech Prusa I3 question December 06, 2014 05:40PM |
Re: Auto Bed leveling Folgertech Prusa I3 question December 06, 2014 07:01PM |
Gannicus
Really need some help here fellas.
Here is what I get returned when running the G28 and G29 commands:
SENDING:G28
>>>g29
SENDING:G29
Bed x: 50.00 y: 50.00 z: 6.08
Bed x: 150.00 y: 50.00 z: 6.08
Bed x: 150.00 y: 150.00 z: 6.08
Bed x: 50.00 y: 150.00 z: 6.08
Eqn coefficients: a: -0.00 b: 0.00 d: 6.08
planeNormal x: 0.00 y: -0.00 z: 1.00
echo:endstops hit: X:134.00 Y:67.50 Z:6.08
The autobed leveling procedure doesn't run when running G29 like it is supposed to in this instructional video:
[www.youtube.com]
Re: Auto Bed leveling Folgertech Prusa I3 question December 06, 2014 09:36PM |
Waltermixx
Gannicus
SENDING:G28
>>>g29
SENDING:G29
[www.youtube.com]
I have not tried it as of yet...
work has been keeping me pretty busy.
holidays coming, so hoping to do it then... what mechanism are you using for the servo? can you post pictures?
Cheers.sorry i know this post was not helpful, i just did not want you to think i was holding back info
Re: Auto Bed leveling Folgertech Prusa I3 question December 07, 2014 12:56AM |
Re: Auto Bed leveling Folgertech Prusa I3 question December 07, 2014 09:24AM |
Re: Auto Bed leveling Folgertech Prusa I3 question December 07, 2014 02:10PM |
Re: Auto Bed leveling Folgertech Prusa I3 question December 08, 2014 08:13AM |
Re: Auto Bed leveling Folgertech Prusa I3 question December 08, 2014 07:32PM |
Re: Auto Bed leveling Folgertech Prusa I3 question December 08, 2014 08:08PM |
Nargousias
I looked and found a specific mention to disable the Max Endstops. I had teh same issue and could not get G29 to work.
#define DISABLE_MAX_ENDSTOPS
After that the G29 did work the first time once. Make sure you have the z axis well up before you run it and be ready to pull the plug.
After that initial run I ran the G28 and then the G29 and my x started lowering and popped out my X nuts from the nut hole. (I was glad I did not glue them or used a soldering iron to melt the edge of the plastic to fix them in place)
I am now going to look up an emergency stop to see if anyone has produced the code yet. I would rather have the button than a power switch. I want something that will tell the system to stop now... immediately....
Re: Auto Bed leveling Folgertech Prusa I3 question December 09, 2014 08:44PM |
Re: Auto Bed leveling Folgertech Prusa I3 question December 31, 2014 07:35PM |
Re: Auto Bed leveling Folgertech Prusa I3 question February 15, 2015 10:23PM |
Re: Auto Bed leveling Folgertech Prusa I3 question May 09, 2015 05:31PM |
Re: Auto Bed leveling Folgertech Prusa I3 question September 28, 2015 12:03AM |
