first startup problems December 16, 2014 04:11PM |
Re: first startup problems December 16, 2014 06:27PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: first startup problems December 18, 2014 08:32AM |
Re: first startup problems December 19, 2014 05:43AM |
Re: first startup problems December 19, 2014 11:20AM |
Re: first startup problems December 19, 2014 12:36PM |
hillybilly52
No, I want sure if anythingneeded to be. what do I need to upload.?
Re: first startup problems December 22, 2014 04:09PM |
Re: first startup problems December 23, 2014 02:01AM |
Re: first startup problems December 23, 2014 10:53AM |
Re: first startup problems December 23, 2014 01:26PM |
jrcaster
Looks like you don't have all of the files, and you don't need blink. Where did you get the printer from? You should go to their website and download all of the files for marlin. Make sure they are in the same folder and you may have to rename the folder to the same name as the .ino file. Go into your arduino dashboard and open the .ino file. Make sure all of the files that you downloaded are tabbed across the top, then edit the configuration.h file to make sure it is set up for your printer. Then upload that file set to the arduino just like you did the blink program. Then you should be able to link to it with pronterface.
SteveRoy
Not sure what's causing the errors.
I have ver 1.05 of the Arduino IDE and downloaded Marlin from the github site.
You just need to open the Marlin.ino file in the IDE - that will open the others in the IDE, you will see them in the tabs.
Try a test compile (not upload) with the stock Configuration.h file by clicking the check-mark of the IDE.
If that compiles OK then change the Configuration.h and try again.
Re: first startup problems February 04, 2015 04:42PM |
Re: first startup problems February 06, 2015 08:19AM |
hillybilly52
Over the last few months I've been building a Prusa i3,, and last night got to power it up for the first time.
Connected to PC via USB first, seemed OK lights flashing on atmega etc, however when powering from mains, the heated bed and hotend started heating and the extruder stepper motor starts stepping). However the PC software(Pronterface) doesnt seem to be able to connect to the printer. I think the issue is comms between the pc and the arduino, any suggestions as to how this could be checked out?
Any suggestions would be appreciated.
Re: first startup problems February 06, 2015 08:21AM |
hillybilly52
Finally after 6 weeks of frustration, several PC rebuilds, several cables and boards, I have finally managed to communicate with my Prusa i3. Not sure what exactly resolved the problem in the end, but the printer came very close to being advertised on Ebay!!
Using printerface, I can control the extruder head and flat bed temps, seems to be accurate as I have confirmed the temperatures with an IR thermometer. The extruder appears to be driving properly (although it hasn't seen any plastic yet). So far so good, however when I try to move in any of the 3 axis, nothing is happening, well nothing is moving, the motors sound like they are trying to drive but I assume they are just stalling.
Any suggestions? my system consists of a mega2560 with RAMPS 1.4 and a bulldoglite extruder head.
Any advice/guidance would be greatly appreciated after all this time I feel I'm actually getting close to owning a working printer.
Cheers
hillybilly52
Re: first startup problems February 07, 2015 12:58PM |
Re: first startup problems February 07, 2015 01:13PM |
Re: first startup problems February 08, 2015 01:34AM |
