ABS Juice for ABS prints (ABS plastic melted in 100% Acetone from hardware store)
Aqua Net Hair Spray the bright pink label for PLA.
The trick for both of them is to make sure you coat the area you want to print well, usally two coats.
The ABS juice when you have enough it will have a milk white appearance.
The PLA hairspray method you spray it till its wet once and then let it dry then spray it a second time not as much just a good coat. I usually heat it up right away after the sencond spray and by the time the print starts its dry.
