Re: X shift January 10, 2015 04:12PM |
check your slicer settings. this usually happens when the non-print movements are above 120mm/sQuote
rich1812
I don't really know what the cause of the problem is. My printer was working fine since I built it until now. I was going to print a thin disk. Somehow, when the first layer was printed, it was in the correct location on the glass, but once it gets to the second layer, the X shifted. (See attached shifted.jpg.) I am not sure what causes it, but I think it has something to do with the belt tension. If I am correct, how much tension should there be?
Re: X shift January 10, 2015 08:41PM |
Re: X shift January 11, 2015 07:24AM |
Re: X shift January 11, 2015 04:10PM |
