Anonymous User
PID Autotune failed! timeout My heat cartridge cannot heat up. January 11, 2015 04:41AM |
// Comment the following line to disable PID and enable bang-bang. #define PIDTEMP #define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current #define PID_MAX 255 // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current #ifdef PIDTEMP //#define PID_DEBUG // Sends debug data to the serial port. //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX #define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature // is more then PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max. #define PID_INTEGRAL_DRIVE_MAX 255 //limit for the integral term #define K1 0.95 //smoothing factor within the PID #define PID_dT ((OVERSAMPLENR * 10.0)/(F_CPU / 64.0 / 256.0)) //sampling period of the temperature routine // If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it // Ultimaker #define DEFAULT_Kp 45 #define DEFAULT_Ki 4.2 #define DEFAULT_Kd 120 // MakerGear // #define DEFAULT_Kp 7.f // #define DEFAULT_Ki 0.1 // #define DEFAULT_Kd 12 // Mendel Parts V9 on 12V // #define DEFAULT_Kp 63.0 // #define DEFAULT_Ki 2.25 // #define DEFAULT_Kd 440 #endif // PIDTEMPCan any one help me?
Anonymous User
Re: PID Autotune failed! timeout My heat cartridge cannot heat up. January 11, 2015 07:58PM |
Re: PID Autotune failed! timeout My heat cartridge cannot heat up. January 11, 2015 10:01PM |
Re: PID Autotune failed! timeout My heat cartridge cannot heat up. January 12, 2015 12:37AM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: PID Autotune failed! timeout My heat cartridge cannot heat up. May 10, 2015 03:58AM |
Re: PID Autotune failed! timeout My heat cartridge cannot heat up. May 11, 2015 02:51PM |
Re: PID Autotune failed! timeout My heat cartridge cannot heat up. September 06, 2015 06:32PM |
milkypostman
Do you have a fan blowing on the nozzle by chance?
Re: PID Autotune failed! timeout My heat cartridge cannot heat up. September 07, 2015 02:23AM |
Re: PID Autotune failed! timeout My heat cartridge cannot heat up. September 07, 2015 12:22PM |
Re: PID Autotune failed! timeout My heat cartridge cannot heat up. September 07, 2015 12:26PM |
Re: PID Autotune failed! timeout My heat cartridge cannot heat up. September 07, 2015 12:30PM |
