Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 11, 2015 07:57AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 12, 2015 01:23AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 12, 2015 06:43AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 12, 2015 08:20PM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 13, 2015 04:01AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 13, 2015 04:45PM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 13, 2015 09:04PM |
GeeBee
The voltage across the resistor being several mV instead of the expected 12V (or should it be 24V or else?) I think that means that the MOS-FET is defect, am I correct?
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 14, 2015 06:16AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 14, 2015 08:25AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 14, 2015 09:40AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 14, 2015 11:05AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 05:00AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 07:49AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 08:02AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 08:05AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 08:19AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 08:29AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 08:45AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 08:51AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 08:57AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 09:01AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 09:06AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 11:01AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 15, 2015 11:11AM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 19, 2015 04:35PM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 19, 2015 04:48PM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 20, 2015 09:38AM |
I can not see the switching which the Arduino does on Q1 upon the reception of my command or would the following sequence of entries in the Repetier-Log tell me as much?
22:09:17.187 : N704 M109 S40 *127
22:09:17.656 : ok
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 20, 2015 05:34PM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 20, 2015 05:44PM |
Re: Hot end on Prusa_Mendel i2 not heating up any more. Thermistor OK AFAIK January 31, 2015 04:34AM |
