D9 ground output problem January 12, 2015 08:37PM |
Re: D9 ground output problem January 13, 2015 03:28AM |
Re: D9 ground output problem January 13, 2015 05:34AM |
Re: D9 ground output problem January 13, 2015 06:48AM |
Re: D9 ground output problem January 14, 2015 10:58PM |
Thanks for the help. It seems it is just a fact of clone boards manufactured to low tolerances in China. I think I'll just replace it with a smoothieboard.Quote
MindRealm
With a meter on the power input ground for reference, the positive terminal in D9 will always read around 12v, regardless of whether the fan is turned on in G-Code (M106). The negative terminal reading depends on the duty cycle of the PWM output of the Arduino, driving the negative (ground) through the mosfet. Technically, the output on the negative terminal is always at ground potential when on, but the pulse width makes the output seem to drop and emulate a reduced potential to ground. The D9 negative is actually turning off and on VERY rapidly when M106 is passed to the controller.
Try this.
Send M106 S0 and measure the DC voltage at the D9 positive and negative. This should show 0 volts. If any voltage is present (like the 2 volts you mentioned), disconnect the wiring that is landed on D9 and check again. If there is still voltage present, your mosfet is damaged. If the voltage goes away, something else is putting the 2 volts on the line.
Let me know what you find. (I'm following this thread and will continue to help!)
