Unknown Aurora controller
Posted by aceshuttle
January 14, 2015 12:28PM
Hi All
I have a new Aurora 605S printer and it is working great.
I would like to update and fine tune the firmware, but I do not know what controller I have.
I have been to the manufactures web site and even searched Google images, but I have not seen another one like it.
I know it is running marlin firmware but that is as far as I have gotten.
I have included an image, so if anyone recognizes or has another way to identify it please let me know.
open | download - Aurora 605S main board.jpg (84.1 KB)
Re: Unknown Aurora controller
January 14, 2015 07:48PM
looks custom
looks like a one board ramps type solution.
Check the main chip for a 2560 or a 1284p type number...
If it is one of those it should be possable to get a standard marlin onto it, BUT and this is a large but, you will need to work out what pins are connected to what part of the board.
January 15, 2015 12:23AM
Thanks Dust
After looking it is a 2560 chip.
The board currently has Marlin 1.0.0 firmware running on it.
So if I were to use Arduino to load Marlin 1.0.1 on it what board would I select from the list, and how do I determine the pins?
January 15, 2015 02:15AM
that’s the tricky bit... you either have to trace out the cct board or be provided with the pin definitions from the supplier
It may be compatible with something that already exists, but there is no way to know till you trace it out.
Edited 1 time(s). Last edit at 01/15/2015 02:15AM by Dust.
January 15, 2015 04:24AM
this board is made in china called the mks base 1 .. pin compatible with megatronics 2
blog
taobao
January 16, 2015 02:27AM
That's it!
Thanks to all for your help.
January 18, 2015 06:03AM
nice.. now if only the manufactuters would be nice enough to spend that extra 1c per board and put a label on it, eveyone would be happy!
I do see that the images above do have a label, just the first image doesnt...
Edited 1 time(s). Last edit at 01/18/2015 06:06AM by Dust.
January 18, 2015 07:23AM
It even has a Wiki page
