Can I build a heatbed assembly without a glass print bed? January 14, 2015 05:53PM |
Re: Can I build a heatbed assembly without a glass print bed? January 14, 2015 07:08PM |
Re: Can I build a heatbed assembly without a glass print bed? January 14, 2015 07:35PM |
Admin Registered: 14 years ago Posts: 7,221 |
Re: Can I build a heatbed assembly without a glass print bed? January 14, 2015 07:46PM |
Re: Can I build a heatbed assembly without a glass print bed? January 14, 2015 08:16PM |
Re: Can I build a heatbed assembly without a glass print bed? January 14, 2015 11:26PM |
Re: Can I build a heatbed assembly without a glass print bed? January 15, 2015 12:27AM |
Re: Can I build a heatbed assembly without a glass print bed? January 15, 2015 05:40AM |
Re: Can I build a heatbed assembly without a glass print bed? January 15, 2015 08:46AM |
Be careful using aluminum, or anything else that is electrically conductive, so that you don't short out anything (led connection, power wiring, grid) on the heated bed circuit board!Quote
jrcaster
find a cheap picture frame and take the glass...
Re: Can I build a heatbed assembly without a glass print bed? January 15, 2015 01:37PM |
MindRealm
Good advice:Be careful using aluminum, or anything else that is electrically conductive, so that you don't short out anything (led connection, power wiring, grid) on the heated bed circuit board!Quote
jrcaster
