Probleme infill prusa air 2
Posted by kevin3d
January 19, 2015 01:48PM
Bonsoir a tous,
Voilà je m'en remet a vous pour un problème assez complexe a résoudre enfin pour ma part..
Mon imprimante 3d fonctionne, et j'arrive a imprimer quelques pièces mais lorsque j'imprime par exemple des engrenages, le remplissage des dents font une "paté" et non un beau remplissage bien net.. Je vous ai joint le dernier objet imprimé correctement et l'image de celui qui pose problème.. Merci de vos précieuse lumière =) .
Une idée ?? ...
Merci d'avance..
open | download - WP_20150119_002.jpg (319.3 KB)
open | download - WP_20150119_001.jpg (384.9 KB)
Re: Probleme infill prusa air 2
January 19, 2015 02:59PM
Bonjour. Qu'est-ce filament de type utilisez-vous, et quelles sont vos extrudeuse et des températures de lit chauffé? (Désolé - mon français ne est pas bon) smiling smiley
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
Check out my FolgerTech Prusa i3 (plexi) at MindRealm.net
January 19, 2015 03:04PM
Hi David!
Thanks for you reply. smiling smiley I use a PLA with 200°C and my bed at 55°C. I have a an extruder 0.5mm .Thanks for your help and sorry for my bad language smiling smiley
January 19, 2015 03:12PM
The temperatures are good, but the gear image appears to have the fill melted instead of in printed lines. Make sure your slicing software (Slic3r, skeinforge, etc.) has the filament and nozzle sizes set to match your printer.
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
January 19, 2015 05:04PM
Thanks david, I've tried to put the filament 's options at 2.95 instead 3mm. the first run was better but i'll retry tomorrow evening.. i'll send a message smiling smiley Good night smiling smiley
January 20, 2015 03:04PM
Hi david, with the modification of yesterday, the quality is better but i did get down my Z end stop.. I change a type of infill to concentric and it's better too. What do you think ? smiling smiley
Best regards.
January 20, 2015 03:21PM
Still the same problem.. confused smiley
open | download - WP_20150120_003.jpg (462.3 KB)
January 20, 2015 03:51PM
This is a bit of a mess. (Sorry, Kevin)
Please let me know the layer height you have set in your slicing software, or reply with the gcode file you're trying to print as an attachment. (not the .stl file)
Thanks!
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
January 20, 2015 05:20PM
Salut Kevin, ça farte ? (pas pu m'empêcher; lol). Ça semble un peu chaud tout de même. Déjà, as-tu bien configuré ta machine (steps per mm en XYZ) ?
Collective intelligence emerges when a group of people work together effectively. Prusa i3 Folger (A lot of the parts are wrong, boring !)
January 20, 2015 05:25PM
Salut !! Ouep et toi ? apars que je galère sur mon imprimante =) . Oui je pense que mécaniquement et électriquement c'est ok.. Après logiciellement, j'ai réglé comme j'ai pu ^^ .. Ce qui ai etrange c'est que les vases ou les pots s'imprime presque parfaite ( une legère collure au niveau de la remontée ).. Après effectivement non je ne pense pas toucher au réglage step / mm par defaut :\
Merci de ton aide winking smiley
January 21, 2015 02:45AM
Peux-tu me donner tes valeurs ?
January 21, 2015 01:07PM
Salut ! Est ce que tu peux me dire si les valeurs semble correct ? (Pièces jointe) screenshot slicer
open | download - valeurstepmm.jpg (96.8 KB)
January 21, 2015 01:23PM
Hi david !!
this my layer's options in slicer smiling smiley .
I can't reply with de GCODE because the website doesn't work when i try to send it..
open | download - slicer.jpg (152 KB)
January 26, 2015 02:45PM
Bonsoooirr smiling smiley
Quelqu'un sait il où paramétrer les mouvements de l'extruder pendant les déplacements, les moments ou il n'imprime pas ainsi que le repositionnement du fil ( quand il rejette et ravalle un peu le fil ^^ ) .. Merci les amis smiling smiley!
