Fitting the heater in the metal body January 21, 2015 11:04PM |
Re: Fitting the heater in the metal body January 21, 2015 11:38PM |
Re: Fitting the heater in the metal body January 21, 2015 11:44PM |
Re: Fitting the heater in the metal body January 22, 2015 11:49AM |
MindRealm
The heater cartridge gets plenty hot enough to heat the aluminum block without needing to worry about maximizing the surface area the is in contact with the block. If it would make you feel better you can prep the block with heart sink compound before inserting the cartridge.
Also, there is no concern about expansion of the cartridge within the block since they will both expand when heated.
You will need to pay attention to insulating the block once the heater cartridge and the thermistor are installed, to minimize the radiated heat from interfering with the rest of the components. Otherwise, you will find that the heat rises into the filament throat and can cause jams or noodling between the extruder and the throat.
Re: Fitting the heater in the metal body January 22, 2015 12:43PM |
