GT9S exrtuder problem January 25, 2015 06:24AM |
Re: GT9S exrtuder problem January 25, 2015 07:45AM |
Re: GT9S exrtuder problem January 25, 2015 03:08PM |
Re: GT9S exrtuder problem January 26, 2015 03:43AM |
Or I am doing something completely wrong. I also tried to find some feedback for this head from other users, but nothing found, it looks like I am the first one who tries to use it
Re: GT9S exrtuder problem January 26, 2015 04:07AM |
Re: GT9S exrtuder problem January 26, 2015 04:16AM |
Re: GT9S exrtuder problem January 26, 2015 07:54AM |
vagran
Which side do you mean? Like in the original head design? Then, as I said, the head is unable to heat more than 150C because of heat leak through the fan mounting plate. However, I think, it is possible not to screw the plate to the heating block and insert some heat insulation between the plate and the heating block. But I will firstly try to make a fan duct from metal sheet - it is easier for me because I can leave my current head mounting as is, and also it will be additional radiator area for the tube cooling. I will make a post about the result.
Re: GT9S exrtuder problem January 26, 2015 08:09AM |
Re: GT9S exrtuder problem January 27, 2015 03:27AM |
Re: GT9S exrtuder problem January 27, 2015 03:39AM |
