Hi, I'm working my way through a prusa i3 build but my stepper motor wire colours seem to be different from the guides I have seen. My motors have red, green, blue and yellow. I know how to work out the two pairs, but is there a particular colour sequence I should use so that the stepper direction is correct with the default firmware settings? I have Marlin firmware.
Another short question I have is regarding the thermistor wire. I used speaker cable for the heated bed and then just used the same stuff for the thermistor, as opposed to thermistor wire that I've seen mentioned in the build guides. Would this matter? I imagine not, unless the thermistor wiring itself has sufficient resistance to influence the reading.
