Extruder doesn't keep temp after hitting target
Posted by ipsilondev
January 30, 2015 04:54PM
Hi everyone grinning smiley
i'm having a weird problem in my reprap prusa mendel, for some reason, when it hits the temp target of the extruder, it doesn't maintain it and goes down till i hit "set" in pronterface.
i used slic3r to generate the gcode from the STL, and there i set 280 degrees for the first and the rest of the layers, then loaded in pronterface, and i enabled debugging, and only saw this 2 commands at the beginning:
N2 M104 S280 *77
N5 M109 S280 *77
i have Sprinter as firmware and using ramps 1.4 and arduino mega.
Any hints of what could be the problem or where i should look at? i'm completely clueless sad smiley
thanks in advance !
Re: Extruder doesn't keep temp after hitting target
January 31, 2015 03:39AM
What filament are you using that takes 280 degrees? Also in Marlin I think that the max temp for the extruder is set to 275degrees. Remember these are celsius and a lot hotter than you think. ABS runs at 220C and PLA at 195C.
February 02, 2015 05:11AM
yes, you were right, there was a limit in the firmware, i could raise it in the end.
i'm having big troubles with with this filament, is labeled a PLA but at 195 doesn't go through the extruder and i need to raise at least to 220. and at 220 i have 0 adherence (i already tested with several heatbed config, from 60 to 120). i need to put it to 250/260 so it doesn't clog, even at pretty slow speeds (5mm/s).
i will keep trying later, or try to get another filament from another provider to compare it and try to figure it out what's going on.
Regards.
February 03, 2015 02:21AM
Your tip might be clogged. Find a welding tip cleaner. The smallest wire will run through a .4 nozzle, and the second wire will run through a .5 nozzle.
You might also be trying to run at too high of a speed.
If you are getting no adherence, your tip might be too far from the bed. Recheck your Z hight calibration. A lot of people like to use a piece of paper to set their hight, I like to use a .002 inch feeler guage to set my bed. Also set it at temps for both the bed and extruder.
