Fan Problem, D9 not working [Prusa i3 Rework] January 30, 2015 07:23PM |
#ifndef MOTHERBOARD #define MOTHERBOARD BOARD_RAMPS_13_EFB #endif
Re: Fan Problem, D9 not working [Prusa i3 Rework] January 30, 2015 09:00PM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 01, 2015 06:55AM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 05, 2015 08:37AM |
Ano
Heay, yeah, everything here, multimeter, soldering iron, oszilloskop, tool kit. I got my first print running, went pretty good so far. But the fan was on all the time.
What I would like is, the fan to be active while the preheating begins until after the print, when the hotend is cooled down to about 45°C. So that it stops then to
not always be that loud.
Did my second print and in fact: it's not that bad with always on fan. I thought it will destract me, but when the printer is not running, I'll always switch it off anyway.
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 05, 2015 01:53PM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 23, 2015 09:45AM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 24, 2015 02:45AM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 25, 2015 12:34PM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 25, 2015 01:38PM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 25, 2015 02:25PM |
touchthebitum
Hello!
I found the problem, the firmware 1.4 is the problem, I turned back on the 1.3.1 and the problem solved.....
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 25, 2015 02:28PM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 26, 2015 04:26PM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] February 27, 2015 01:24AM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] March 04, 2015 11:33AM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] March 05, 2015 01:51AM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] April 10, 2015 02:29PM |
coolcasa
I solved the problem with the software WinMerge where I compared the two configuration.h 1.4 and 1.3.1
I modified the command:
#define FAN_SOFT_PWM
in
// #define FAN_SOFT_PWM
now works in 1.4
I hope I have helped you
Re: Fan Problem, D9 not working [Prusa i3 Rework] April 10, 2015 02:57PM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] April 10, 2015 05:14PM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] April 11, 2015 02:21PM |
Re: Fan Problem, D9 not working [Prusa i3 Rework] July 28, 2015 06:24PM |
