Extruder stepper motor too slow
Posted by drdray1
January 30, 2015 10:26PM
HI I have a prusa i3 and i have printed a couple objects that turned out ok. So i decided to calibrate the machine better. Once i was done with this calibration my extruder stepper motor would output the correct amount of filament but now it does it extremely slowly. Ive checked to make sure the motor isnt fryed which its not, it IS getting the correct voltages, not to much or to little, and nothing is rubbing against it! Im stuck. Any other ideas? btw im using Marlin firmware Thanks in Advance!smiling smiley
shoot nevermind my feedrate was really low in printerface im sorry but this may help somebody else in the future!!
Edited 1 time(s). Last edit at 01/30/2015 10:34PM by drdray1.
Re: Extruder stepper motor too slow
January 31, 2015 03:09AM
Clean your extruder tip. I use a welding tip cleaner. The smallest wire works with a .4mm tip, and the second one works with a .5mm tip.
You should be able to pick one up at Lowes or your local home center, or harbor freight.
Edited 1 time(s). Last edit at 01/31/2015 03:30AM by jrcaster.
January 31, 2015 06:49AM
Is it a direct drive extruder ? Can you describe your calibration procedure ? How are set your microstepping settings ?
Collective intelligence emerges when a group of people work together effectively. Prusa i3 Folger (A lot of the parts are wrong, boring !)
